Old 09-03-2009, 11:38 PM   #1
smoooth's Avatar
smoooth is on a distinguished road
What am i missing?
OK, I have a set of gen 1 ez street stuts that are replacing my UA struts. Just wondering what im missing? I cant seem to figure out what order all the stuff goes in. And i know im missing a few pieces. Also i know i dont have the top bearings for sure! Where can i get them besides the stealership?
smoooth is offline   Reply With Quote
Old 09-06-2009, 08:35 AM   #2
ogerdgonz's Avatar
Re: What am i missing?
Are those the original design of the ES strut that uses the factory top hat?
Old 09-07-2009, 12:26 AM   #3
smoooth's Avatar
They are the original ones i think. And do they use the top hat? thats what i dont know? Thanks in advance,
Old 09-07-2009, 12:53 PM   #4
ogerdgonz's Avatar
Yes the original design used the stock top hats. I think you could possibly go with Cusco Camber plates. Personally I would not waste my time on the original design ES struts, they are going to clunk sooner or later.
Old 09-15-2009, 03:41 AM   #5
whitej47 is on a distinguished road
what are you going to do with the UAs? smooth, the 2nd and 3rd gen came with their own top plates that had a bunch of hardware, rings, bushings, etc. You could make those plates work, but you would have to find all of that other stuff somewhere!
The 2nd+ gens have like white ceramic bushings that allow for minimal rotation so that the shaft does not twist...this design will be tough to reproduce if you are not using the ES equipment. Maybe ES can help you out...long shot tho
whitej47 is online now   Reply With Quote
Old 09-23-2009, 04:04 PM   #6
jx1379's Avatar
jx1379 is on a distinguished road
i dont think the drop plates will work with the 1st gen struts? it looks as though you have everything but the oem mounts (see pic below)
stepts to put together:
1 - put rubber washer on
2 - put larger metal washer on
3 - put small metal washer on
4 - put oem mount on
5 - put 1/2" nlyon lock nut on
6 - install and have fun
jx1379 is offline   Reply With Quote
Time for Brake pads already?
Page generated in 0.15733 seconds with 14 queries
