Old 08-20-2009, 07:27 PM   #21
crxgames's Avatar
Re: well it finally happened.
He's got plywood there anyway, remember?
Old 08-20-2009, 07:55 PM   #22
thats Reverend ^^
gothbox's Avatar
lol, hey its not plywood, its MDF. Get it right, lol.
Old 09-23-2009, 03:42 PM   #23
jx1379's Avatar
jx1379 is on a distinguished road
figured i would give my 2 cents since i had sleeved bags as well but here goes: from what the techs told me at Airlift.......the front/rear bags are water burst tested at 600psi so i doubt 200-250 psi would blow them. its pretty cool to - hooked the airline up to a water line then put in black box to blow up.....its freakin loud too when they pop!
now for the possiblitlies i can think of: i had the sleeve bags when i first bought the ES kit and they lasted almost 2 yrs. my driver rear bag decided to get a pinch at the top of the bag where o-ring clamp attaches the bag to hardware which in turn is why my sleeve blew while driving (good times as we all know)!!! it could have also been that your bag was wearing out due to all the use of ups and downs and just wore out and blew!
but on the flip side of everything - did you find any electrical problems that would otherwise exlcude the bag defects? glad you were able to limp your way home without any real damage to the box.
jx1379 is offline   Reply With Quote
Old 09-23-2009, 03:50 PM   #24
859Toaster's Avatar
Hey Jay.... GOOD JOB ON BRINGING UP AN OLD TOPIC :-P
Old 09-23-2009, 04:12 PM   #25
jx1379's Avatar
thats what happens when you get bored at work - way to stay on top of the clubxb threads (you post whore you)!
and its not that old of a thread - maybe a month. i have been known to revive some year old threads due to boredom!
Old 09-23-2009, 05:43 PM   #26
859Toaster's Avatar
hahaha. Did you learn how to post pics yet?
Old 09-23-2009, 05:44 PM   #27
jx1379's Avatar
i sure did my friend - tanks for the lesson even though i am the I.T. guy!
stenger - check out the thread for pics with background scenery and tell me what ya think!
Old 09-23-2009, 06:05 PM   #28
regulatin' on foolz......
http://scionlife.org/Scion_Docs/2004...m/inspec40.pdf
Air inlet drain line for yer evap canister
Originally Posted by gothbox View Post
there was one small other bit of damage.
it snapped the hose boxed in red in pic clean off. that small box it is attached to faces the outside of the car not like in this pic i found for an example. I am sure I can reattach it with something if it needs to be back on there but the car has run perfect since this happened, so idk. I have driven it about 100miles with it broke off as well.
Old 09-23-2009, 10:32 PM   #29
thats Reverend ^^
gothbox's Avatar
well I am sure the bag had a weak spot or whatever, and the 200+psi was not teh only cause of it, but having that much put to it IS what caused it to blow, in combo with said spot. Who knows how much loger it could have lasted with not putting 200+psi to it all at once. I have run them for about a year and a half before this happened with prob 30K miles on them, so they have seen their use thats for sure.
and it was a loose ground to my pressure switch that caused my compressor to not cut off.
But all is good, I got a box from EZ last week, just waiting on this rain that has been going on for the past week and half to swap stuff out.
Thanx for the info Sakura, so basically its just part of the emissions crap , I have actually forgot about it and have driven the car several hundred miles with it broke off with no side effects that I can tell.
Time for Brake pads already?
Page generated in 0.22416 seconds with 12 queries
