05-14-2009, 04:15 AM
| tapping into digital kit my es setup is digital. i was wondering if theres anyway to tap into the wiring so i can run roller switches but still keep the digital setup. has anyone done this before? |
05-14-2009, 12:24 PM
#2 | | Suspension Whore
| Re: tapping into digital kit Es will claim that the brain box will need to be reprogramed in order to do it, which meana downtime. This is reason number 651 why I hate the digital kit from es.
Just rewire the valves and disconnect the valve harness from the valves. Make sure the sending units are still connected to the brain box, for your read out. Wire in a real switch set up (switches get the bitches, buttons get nothing) and you will be good to go.
I did this on my cavalier, and it worked 100 times better. Also keep the ecu in manual control.
If I were you I'd sell the es kit, and get a dakota digital screen, new sending units, and a basic switch box. Dakota gauges are far more accurate than es will ever be. And will give you far less problems in the future. Because they don't need a brain box to opperate. |
05-15-2009, 11:25 PM
| Re: tapping into digital kit well in a way i like the digital box because of the built in guages. the thing i dont like is cant control the air up and down like the rocker set up. the digital box is connected with an ethernet cable. what if i tap into each wire to a rocker setup. would that work? |
05-16-2009, 12:09 AM
#4 | | Suspension Whore
| Re: tapping into digital kit You should still be able to use the digital box for gauge read out only. As long as the senders are still connected to the ECU you'll be fine.
Just unplug the harness for the valves, re wire them to a real switch box, make sure the sending units are still connected to the ecu, and done.
If it doesn't work, just pull your re-wire off, and put it back to how it supposed to be. Or wait until someone else explains it a slightly different way, and then do it. Custom Auto Parts, Airbag Suspensions, Rollpans, Bumpers - Fender Bender International
Everything you need for digital read out and to get away from the "brain" box. Custom Auto Parts, Airbag Suspensions, Rollpans, Bumpers - Fender Bender International
Switch Boxes Custom Auto Parts, Airbag Suspensions, Rollpans, Bumpers - Fender Bender International
Better valves than Easy streets manifold valves. |
05-19-2009, 03:19 AM
| Re: tapping into digital kit well i think the only wires going to the valves is pressure sensors i think. |
05-19-2009, 10:35 AM
#6 | | Suspension Whore
| Re: tapping into digital kit I give up, you'll figure it out if you just read a wiring diagram that comes with the kit, or trace out all the wires. |
05-19-2009, 02:49 PM
#7 | | Authorized Vendor
| Re: tapping into digital kit I think you are better off buying a Dakota digital gauge and a switchbox. Once you tap into that wiring you void the warranty and I also am willing to bet you will eventually cause the brain to be fried due to improper ground and then you will be buying the Dakota Digital set up anyway.
Just shop around until you find a good deal on a digital readout. |
05-27-2009, 06:54 AM
| Re: tapping into digital kit Quote:
Originally Posted by 859Toaster I give up, you'll figure it out if you just read a wiring diagram that comes with the kit, or trace out all the wires. | my bad. i looked at the valves and saw another set of wires separate from the sensor ones. |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | | All times are GMT -5. The time now is 07:02 AM. |
