Old 02-01-2006, 10:55 PM   #1
Down4Action1's Avatar
Down4Action1 is on a distinguished road
Send a message via AIM to Down4Action1 Send a message via Yahoo to Down4Action1
Question Tanabe SUSTEC DF210 Springs
I was wondering if any one has or knows someone who has the
Tanabe SUSTEC DF210 springs? I was thinking of getting them because they claim a 2" - 2 1/2" drop. My question is are they worth getting and how is the ride on a 18" rim? do they rub? etc.??? Any feed back you may have would be greatly appreciated!! Also any preferences on other springs would be good too. Thanx!
Down4Action1 is offline   Reply With Quote
Old 02-01-2006, 11:00 PM   #2
You can have as much or as little drop, and still rub. We need to know the offset of the wheels, diameter and width of the wheels, and tire size.
squirrel is online now   Reply With Quote
Old 02-02-2006, 01:05 AM   #3
the brave little toaster's Avatar
the brave little toaster is on a distinguished road
Send a message via AIM to the brave little toaster
i run the tanabe sustec df210s on my scion xb with 17-7.5 konigs and they roll great. good drop on them
the brave little toaster is offline   Reply With Quote
Old 02-02-2006, 01:26 AM   #4
bB Squad
AirecK's Avatar
i had those and i was running 19's ..so yeah you'll be ok!!
Old 02-02-2006, 12:26 PM   #5
ScottyTuned's Avatar
mine slammed me a ton. fender arc to ground im 23.75. thats on 16s with 205/50/16. i really like mine but its almost too low for daily driving really. im gonna have to get some coilovers to raise it back up i think. DF210s are a cheap way to get a really low drop.
scott
Old 02-02-2006, 01:32 PM   #6
bluebb05's Avatar
bluebb05 is on a distinguished road
Send a message via AIM to bluebb05
off topic but i am running goldlines on a 18x8 on a 215 40 18 with a 45 offset in the front and a 35 in the rear and no rubbing and thats a 2 inch all around
bluebb05 is offline   Reply With Quote
Old 02-02-2006, 01:39 PM   #7
im guessin mine have gone 2.5 in front at least. with sub in the back, its probably close to 2.5 also.
scott
Old 02-02-2006, 03:14 PM   #8
excitebox's Avatar
excitebox is on a distinguished road
Send a message via AIM to excitebox
ive been on DF210's for at least 6 months and mine only have a 1.75" drop in the front and maybe a 2" drop in the rear... but that may be due to my camber plate/hub spacer set up im running...
excitebox is offline   Reply With Quote
Old 02-02-2006, 04:37 PM   #9
suspended is on a distinguished road
Send a message via AIM to suspended
the hub spacer shouldn't raise you up, but the camber might a minoot amount...think about it this way...take a pack of cigarettes (for you non smokers a pack of gum), put if flat on a table, now lift up once side to resemble negative camber...notice the hightest point of the tire that would be making contact with the road if you werent' running camber is up higher now...sorry if thats hard to explain
the tanabes are nice springs, i've been on them for almost a year, and my only complaint is rebound in the rear b/c the spring rates aren't as good as most coilovers (b/c of the lack of shorter stiffer struts)...not to mention I wanna go LOWER!!! but for a subtle everyday driver drop, its the best springs to go with in my opinion
suspended is offline   Reply With Quote
Old 02-02-2006, 04:46 PM   #10
excitebox's Avatar
the weight of the car kind of crushes the inside edge of the tire, so from the side it looks like the tire isnt cambered. withe the camber plate next to the swing arm, it tilts the hub and hub spacer up, sinking the rear of the car... i hope that makes sense :-\
Old 02-02-2006, 04:56 PM   #11
theyre nice springs but i know the feeling of wanting to go lower. mine have sagged pretty dang low, but i think HKS or Cuscos may be on the way for me soon enough!
Scott
Old 02-02-2006, 04:58 PM   #12
Thumbs up
ah, good point...i'm gonna have to run an experiment now!!!
I don't think its going to be noticable either way...but i guess just for personal knowlege, i'll have to try it out one day with an extremely accurate ruler
Old 02-02-2006, 09:50 PM   #13
Thumbs up
Thanx for everyones help! Your info has been great! I just picked up some 19" Axis Spiders For my box so I decided to go with the TEIN springs instead!
Old 02-02-2006, 11:50 PM   #14
sounds nice. be sure to post pics when you're done!
Old 02-03-2006, 09:12 AM   #15
excitebox's Avatar
haha let me know the results! :P
Lowering Springs on Scion XB LuminicsBulbsDotCom Scion xB Suspension, Chassis & Brakes 61 02-28-2006 06:41 PM
Question about lowering springs smalltownscionman Scion xB Suspension, Chassis & Brakes 4 01-08-2006 08:23 PM
Time for Brake pads already?
Page generated in 0.24318 seconds with 14 queries
