Old 01-15-2009, 07:53 PM   #1
Suspension Whore
859Toaster's Avatar
Suspension FAQ
Front Suspension Components:
Cross member Assembly (1)
Power Steering Link Assembly (1)
Stabilizer Bar (or sway bar) (1)
Stabilizer Bar Bushings/Brackets (2)
Stabilizer Bar End Links (2)
Ball Joint (2)
Tie Rod (2)
Axle (2)
Front Suspension Member Reinforcement (2)
Strut (2)
Spring (2)
Bump Stop (2)
Strut Mount (2)
Control Arm (2)
Rear Suspension Componets:
Solid Beam Axle (1)
Shock (2)
Spring (2)
Rear Coil Spring Insulator Upper (2) Lower (2)
Types of Upgradeable Suspension:
Coil over
Spring Strut Shock
Air Suspension
Hydrualic Suspension
Types of Upgradeable Suspension Componets:
Control Arm Bushings
Stabilizer Bar Endlink Bushings
Solid Rear Axle Bushings
Motor Mounts
Stabilizer Bar
Strut Tower Bar
Front Suspension Reinforcement (H Brace)
Roll Cage
Coil overs:
Coil overs are a adjustable suspension. There are a few different types of a coil over suspension, but all do the same essential thing. All of them are designed to allow for ride height adjustment with the turn of a wrench or spanner wrench. The best coil over can be debated for years upon years. It all comes down to what the driver wants.
A fully functioning coil over will allow to adjust the ride height, with out effecting the spring pre-load. This is done by raising and lowering the mounting position of the lower suspension mount. This does not effect the travel amount of damping the shock can have, or the pre-load on the springs. A fully functioning coil over will also allow you to adjust the rebound of the shock, and the pre-load on the springs. A stiffer damper or stiffer pre-load will result in a stiffer ride. And just the opposite for a softer damping. It takes some playing to figure out what is best for your driving style.Most brands also come with Pillow block front mounts. Which allow for a more solid ride, and camber adjustments. Brands that are available for this option on the xB are Tein, D2, K-Sport, STD, Blitz, Cusco, Tanabe and a few others. These are just the more popular brands Scion Owners seem to go with.
A semi-adjustable coil over will only provide you with a ride height and damping adjustment. In adjusting the ride height, you are also adjusting the pre-load on the springs. The lower you go, the stiffer the spring rates. The higher, the softer. Some may also come with a damping adjustment. But not all. Read product description before purchasing. Popular brands that Scion Owners seem to go with here is Progress and Tein.
A basic adjustable coil over over is a spring, with 2 hats. It mounts on your OEM or aftermarket strut and only allows you height adjustment. You are limited to what type of shocks you put these on. If you pay high dollar for a set of Koni Yellows then you will have adjustable shocks. But the TRD, Monoroe, Tokico, Tokico OEM, and others will NOT give you adjustable struts/shocks.
Spring Shock Struts:
Springs:
Many of choices to pick from. But the amount of drop and stiffness you look to achieve is up to you. TRD, Road Magnet Tein H-Techs, Tanabe NF210 are mild drops. The Road Magnets however are great in the rear for those who have extra weight in the car (such as a heavy speaker box). They built the springs around that, and to allow the car to sit at a even height even with the extra weight. DF210, Tein S-Tech are the top two selling springs for the xB with one of the best drops. They bring you down around 2"s. There are many generic springs on the market thanks to a website called eBay... So do your research and read your reviews before you dedicate your self to a CHEAP spring.
The Monroe Shock Swap
Monroe Sensa Trac Shocks will provide your xB with a 1/2" drop on top of what springs you choose for the front. The rear shocks, will not lower it more, but provide a better ride. The Monroe Part Numbers are: (rear)Shocks #5987, (front) Struts #71575. These are for a Toyota Echo, but work with our chassis because they share the same platform. The reason they sit 1/2" lower in the front, is because the spring pearchs are mounted 1/2" lower than the xB's OEM struts.
Other brands Such as KYB GR-2, Tokico, and Koni are also good choices for your OEM struts. Each offers their own ride comfort. The Koni Yellows and some high end models of the Tokico's are adjustable.
Air Suspension:
A system where a Strut has a Air Bag placed where the spring would be. You are able to adjust ride height at the flip of a switch, or push of a button. This system is a little more complex, and will cost you about $2000 or more to do. But it will allow you to lay your bumpers on the ground, then raise them up to keep them safe. There are many tricks as to achieving a lower stance by modifying the air suspension assembly, but CAUTION. Do so at own risk. Typically any modification will void any warranty given with the product. Things included on a Air Suspension kit are the Air Bags (2 strut bags which is a bag over strut, and 2 air bags for the rear that replace the rear springs.), air line, valves (4-8 in different sizes from 3/16" to 1"), fittings, air tank, air compressor, pressure switch, control box (switch box), and air pressure gauges. The most commonly used on a Scion xB are the Easy Street/Air Lift kit, and a Do it your self kit from Universal Air Suspension (UAS).
Hydraulic.
Hydraulic is essentially the same as an air suspension. Except where you are using compressed air to inflate a bag, you are using Hydraulic Pressure (a oil) built up by a pump, and feeding it threw a high pressure hydraulic line, and pushing it into a Cylinder. In doing so, it raises and lowers the car. Using this method, you can typically raise higher and faster than a air suspension. However the down sides are, if a line breaks, or seal gives, you have a big mess to clean up, and there is no quick patches. As well as it takes batteries to power the pumps. The batteries remain separate from the vehicles charging system, and you must charge them when they run down.
Suspension Component Upgrades.
There are ways to improve your suspension further after a lowering your car on any of the suspensions covered above. When it comes down to bag for your buck, the Energy Suspension Sway Bar end link bushings take the cake. To do these you need to buy a universal bushing set from Energy Suspension, and a 4" grade 8 Bolt, grade 8 nylon locking washer, and 4 grade 8 washers for EACH side. (so two 4 inch bolts, 8 washers, and 2 nylon locking nuts.)
Another great purchase for little money is the Energy Suspension Control Arm Bushings. These reduce a lot of control arm deflection from bumps, smooth out wheel hop, and reduce body roll. I personally run these, and they are a wonderful Product.
Sway Bars. Companies like Hotckis, TRD, Whiteline and Progress offer upgraded front and rear sway bars. The Scion xB did not come with a rear sway bar from the Factory, unless the original purchaser of the car brand new, asked for the option. In which case a TRD rear stabilizer bar would be installed on the rear. These do a good job of helping the rear of the car stay in geometry and reduce body roll. Another good part to buy. Most go for $100-200 on the rear, and packages can be found for a front and rear upgrade. If you wish to upgrade the front you can do so, but replacing the OEM bushings with Energy Suspension Bushings would be a good option. They offer a stiffer polyurethane bushing which holds the bar in place more, which reduces body roll.
Front Suspension Member Support Brace (H-Brace): These can be found from a vast number of company's. They reduce the flexing from the Suspension Member Support to the Body. The main downside to these is, they are not low car friendly. They have been known to shave down speed bumps, and remove concrete from driveway entrances (like mine).
Strut Tower Bars: These have become more of something to dress up the engine bay with. Only under extreme body stress and flex will these become helpful. If you look at the strut towers (where the top of the strut meets the body), you'll notice that the towers are connected to the firewall. In some cars, there is about 1/2" to 1" gap between those two points. On our cars, they are connected. This helps reduce vehicle flex, body roll, and stress. The front Strut Tower bar may also reduce some vibrations in the suspension. Brands are vast from JIC, Tanabe, TRD, Meagan Racing, ect.
Solid Rear axle bushings. These will help reduce flex, and deflection from the rear wheels hitting bumps. Providing a more solid suspension, less body roll, and less wheel hop (which would only likely to be seen under very hard cornering).
Motor Mounts. These will reduce weight transfer from the motor under hard acceleration, and shifting. This is more a benefit to make up for hp lost at the wheels. HP and TQ can be lost from motion transfer. These will help to reduce that, and reduce front lift, rear squat during hard acceleration and shifting. A second option is a Engine Strut. Which mounts to the top of the motor, to the Strut tower. It is a pressurized gas strut (like a strut for your springs/suspension), and is designed to help hold the engine in place. Weapon R is a producer of these, and the motor mounts you can find from Energy Suspension.
Roll Cages: A roll cage will really stiffen up your chassis, as well as make your car safer (if properly done) in event of a roll over. The more points threw out the car, the stiffer the chassis will become. By tying in multiple points in the car, you make the chassis more rigid. Triangles make for the strongest points. A basic roll cage is a loop which is two points, and mounts behind the drivers seat. They also get into 4, 6, 8, 10, and 12 point cages. The more points, the more your chassis is connected. There is currently NO bolt in, or weld in pre made roll cages for the Scion xB. So this is a custom built item you will have to have done, or do your self.
Old 01-15-2009, 07:56 PM   #2
Resident Rhode Islander
Toup's Avatar
Re: Suspension FAQ
Nice Post Stenger!
Old 01-15-2009, 07:58 PM   #3
Suspension Whore
859Toaster's Avatar
Re: Suspension FAQ
My fingers hurt
3 hours of typing, and double checking some info. lol.
But thanks! Now, lets get this put some gum on the back of this post, and stick it up on the fridge for everyone to see! The goal is to stop some of the repeated over and over questions. Which is why I added the Monroe Info to the post.
BTW. The original version was 568 characters too long, so I had to do some last minute editing.
I guess I can put my short disclaimer here too.
I am no way affiliated, profiting or pushing any products or companies mentioned in this post.
Old 01-15-2009, 08:03 PM   #4
Re: Suspension FAQ
Rep points for doing a great write-up!
Old 01-15-2009, 09:11 PM   #5
swangin 4rm lane 2 lane
ToyBox_02's Avatar
Re: Suspension FAQ
Damn nice write up, it took me three hours to read it. I hope this helps wit tha noobs
Old 01-15-2009, 09:48 PM   #6
adam_a's Avatar
adam_a is on a distinguished road
Re: Suspension FAQ
very informative i learned alot GOOD JOB
adam_a is offline   Reply With Quote
Old 01-15-2009, 10:02 PM   #7
RS4 #303
sdsnybny's Avatar
Re: Suspension FAQ
Great write up, also
Energy suspension now has front sway bar end link kit with proper
bolts/bushings/washers
DITTO^^^^^^^^^^
Old 01-15-2009, 10:02 PM   #8
Blah.. :D
ugly_frog's Avatar
Re: Suspension FAQ
This info is very helpful for me now that im trying to improve my suspension...
Rep. points for sure...
ugly_frog is offline   Reply With Quote
Old 01-15-2009, 10:34 PM   #9
Suspension Whore
859Toaster's Avatar
Re: Suspension FAQ
DITTO^^^^^^^^^^
Well son of a gun. Didn't know they finally made a actual link kit for our cars now. When I did a write up for DIY, it was a piece together thing, but it worked.
Old 01-16-2009, 10:42 PM   #10
JDM101 is on a distinguished road
Re: Suspension FAQ
Nice write up sir. You just narrowed my choices for the springs (DF210 & S. Tech). I just wanna ask, between the 2, what springs would you recommend? I want a springs that can handle 3 adults passenger at the rear. I also planning to buy a 16x8 low offset wheels.
JDM101 is offline   Reply With Quote
Old 01-16-2009, 11:22 PM   #11
Suspension Whore
859Toaster's Avatar
Re: Suspension FAQ
DF210's are a tad stiffer. I'd rock them, Oh wait! I DO! lol
Just match them up with some stiffer shocks.
Old 01-18-2009, 04:18 AM   #12
Re: Suspension FAQ
How about if i pair it with the Monroe 5870 struts?
Old 01-18-2009, 11:52 AM   #13
XBatScionX is on a distinguished road
Re: Suspension FAQ
awesome info in this it actually cleared up alot of questions i had. ofcourse now i have a new one....
do the motor mounts really make a noticeable difference?
XBatScionX is offline   Reply With Quote
Old 01-18-2009, 12:49 PM   #14
Suspension Whore
859Toaster's Avatar
Re: Suspension FAQ
JDM~~~ I am not sure. I know some run them, but I would imagine they'd that bumps a lot better in the rear. I've notice with my set up, which is pretty stiff for a spring set up (i have extras), that my ass end likes to slide out from under me now. So I need to upgrade my shocks. I am going to do a little research in the next few days about which rear shocks to go with. Options are, Koni yellow, KYB GR-2, Monroe, and Air Shocks (forgot to add them to the faq., but they are just what they say. A tire valve with 2 air lines hooked to the shocks, you then fill them with a air pump/compressor. I supposed with some good planning in engineering you could make a 1 or 2 gallon tank, and two 1/4" or 3/16" valves work, with a air compressor). So I will let you know.
Bat~~~ I can't be sure about motor mounts. In past cars, I upgraded motor mounts. In my LD9 cavalier (2.4 twin cam, yielding 150hp and 155tq stock, B&M shift kit, intake, stainless cat back) I ran a upper motor mount insert (fit around the stock one to fill gaps) and a solid lower. It added vibrations to the car at idle, but made shifting smoother, and eliminated some wheel hop. Of course, that was working with 50hp more, and more tq. However, it still should help the motor from moving around and flexing.
Old 01-18-2009, 08:06 PM   #15
Re: Suspension FAQ
^Thanks sir. That would be a big help for me and other newbies here.
Old 01-18-2009, 09:07 PM   #16
aslader13 is on a distinguished road
Re: Suspension FAQ
gret info, it helps to find so much specialized xb info all on the same site. the more prople can give for info the better.
aslader13 is offline   Reply With Quote
Old 01-20-2009, 12:35 AM   #17
Re: Suspension FAQ
thanks alot toaster.
so after reading this yesterday ive been on the hunt for some DF210's. are there any suggestions for any other springs that might be stiffer to carry a full load of ppl without bottoming out???
i guess my stock springs are done because goin up a driveway is killer.
Old 01-20-2009, 09:44 AM   #18
Suspension Whore
859Toaster's Avatar
Re: Suspension FAQ
For the rear I would reccomend swapping shocks. But your going to have to pay extra for a shock that will help hold weight. I'm pretty sure the koni yellow is the shock that will do the trick there. You will have the ability to stiffen the rear when loaded, and soften it back up when not.
I have read that the gr-2 from kyb is a decent shock, and a lot of people here prefer the Monroes. I don't know anybody running tokicko hp or there adjustables on here but they are pricey.
I have decided on doing koni yellow struts and shocks for my car. I like the adjustability and konis never let me down in past cars.
And depending on how tight your front end is, you deffently need a stiffer shock in the rear to keep it from breaking loose. Cody has actually been behind me while I was backroading towards his house... And yeah, my ass end came off the ground and got loose when coming back down. I was only doing 65. The front end of my car however was perfect. It went right where I pointed it.
Old 01-21-2009, 10:08 AM   #19
RS4 #303
sdsnybny's Avatar
Re: Suspension FAQ
Unless they have changed the design the Koni's (in the rear) have to be unbolted to adjust the rebound.
Koni North America - ITT
Old 04-27-2009, 12:57 AM   #20
no_lines's Avatar
Re: Suspension FAQ
im am really dissapointed that you didnt go into very much detail
Body Drop on 20's
Page generated in 0.26288 seconds with 13 queries
