Old 07-21-2009, 05:28 PM   #41
Sleeper
hellmitre is on a distinguished road
Send a message via AIM to hellmitre
Re: Suspension FAQ
I'm looking at a set of Tanabe Pro S-OC coilovers. They're selling for $854 shipped. Is that a decent price? And I can install that myself with a jack and jackstands, correct?
That ought to lower and stiffen the ride, I'm thinking. Performance (without a huge drop in ride comfort) is what I'm looking for. Hard cornering tends to induce some body roll.
hellmitre is offline   Reply With Quote
Old 07-22-2009, 01:06 AM   #42
Suspension Whore
859Toaster's Avatar
Re: Suspension FAQ
Anytime you go coilovers, don't expect "comfort" from them. You want comfort, you go air, or leave it stock. lol.
But yeah, no special tools needed. 10mm, 17mm, 19mm, BFH and a BFScrewdriver, then a lug wrench is about all you'll need. Go Toyota! lol
Price isn't bad. Little below the Ksport D2 price, and just a tad higher than progress.
Old 07-22-2009, 07:29 PM   #43
Daris's Avatar
Daris is on a distinguished road
Re: Suspension FAQ
Originally Posted by 859Toaster View Post
Its pretty easy to do, just need basic metric hand tools. Having a friend will make it go a lot smoother.
And look around on classfieds, a set pops up from time to time.
this is what I want right? is this a good deal?
advancespeedshop.com/tanabe-df210-springs-0407-scion-tdf081-p-4830.html
and this?
shockwarehouse.com/site/product.cfm/id/288270/name/60774-Air-Lift-1000-Air-Spring-Kit-Murano-and-Scion
Daris is offline   Reply With Quote
Old 07-22-2009, 07:37 PM   #44
Suspension Whore
859Toaster's Avatar
Re: Suspension FAQ
Springs are correct, but what you're looking at is a "assistance" bag. It goes inside the spring and inflates and deflates to help lift the car under heavy loads or towing... So the air lift is NOT what you want.
This is what you want for rear shocks...
http://cgi.ebay.com/ebaymotors/2-Rear-KYB-GR-2-Gas-Shocks-SCION-xA-xB-2003-05-05-2006_W0QQitemZ390045172456QQcmdZViewItemQQptZMotor s_Car_Truck_Parts_Accessories?hash=item5ad08102e8& _trksid=p4506.c0.m245&_trkparms=65%3A12|39%3A1|72% 3A1171
Old 07-22-2009, 07:47 PM   #45
Daris's Avatar
Re: Suspension FAQ
ok, cool.
is there a DIY guide for the installation of these to items?
Old 07-22-2009, 08:20 PM   #46
Suspension Whore
859Toaster's Avatar
Re: Suspension FAQ
rear shocks are straight forward, remove 3 nuts, install 2 back on (reuse bottom bolt, new top bolt comes with them)...
Springs are also straight forward on the rear.
There are install guides around here, but i don't much feel like searching for them right now. lol
Old 07-22-2009, 08:57 PM   #47
Daris's Avatar
Re: Suspension FAQ
ok, I'll look.
thanks alot
one more question, will lowering throw my camber off? if so, can I move the camber or do I need a camber kit? do I need to get a alignment done after?
thanks
Old 07-22-2009, 10:28 PM   #48
Suspension Whore
859Toaster's Avatar
Re: Suspension FAQ
you'll be fine, but its not a bad idea to go for an alignment afterwards.
Old 10-20-2009, 08:28 PM   #49
IloveSpeedbumps is on a distinguished road
Re: Suspension FAQ
Ok, so i attempted to install Randodes air stunner front struts in place of my easy streets, the randodes have the fitting on the bottom. How do you guys run your lines?
IloveSpeedbumps is offline   Reply With Quote
Old 10-20-2009, 08:41 PM   #50
no_lines's Avatar
Re: Suspension FAQ
if your talking bout what im thinkin ours are probably the same im running chassie tech right now, my lines are run up beside the frame and splits near the exhaust and goes across where the cv joints are
Old 10-20-2009, 10:00 PM   #51
Suspension Whore
859Toaster's Avatar
Re: Suspension FAQ
run them down the strut. That's what I did on my cavalier. But leave enough slack so you don't put tension on the line. That can result in an epic fail.
Old 10-30-2009, 05:44 PM   #52
Re: Suspension FAQ
Struts: xB (on the left) vs Echo (on the right).
Shocks: xB (on the right), Echo (on the left).
Old 10-31-2009, 12:05 AM   #53
Suspension Whore
859Toaster's Avatar
Re: Suspension FAQ
Good add. But they should be KYB Echo vs. xB Tokico OEM.
Old 11-05-2009, 02:15 PM   #54
oH_SiKKx is on a distinguished road
Re: Suspension FAQ
thx 4 the part numbes on the monroes
oH_SiKKx is offline   Reply With Quote
Body Drop on 20's
Page generated in 0.22094 seconds with 12 queries
