Old 11-11-2009, 09:18 PM   #1
nclibra1985's Avatar
nclibra1985 is on a distinguished road
Squeak/grown while turning
My 06 scion XB just developed a squeak,whine or groan while turning. Generally only does it when doing a pretty tight turn.
Earlier today we replaced a bad driver side wheel bearing. The noise didn't develop till after we got done doing that. The moan & roaring noise went away immediately after replacing the wheel bearing.
But now we have this new noise issue. And while driving at any speed there is a slight metal on metal sound. Brake pads were new as of 5K miles ago. I did take off the wheels to check the pads and they look just fine.
Any ideas? I noticed on the front side of the driverside rotor is two very slight grooves in the rotor surface that was not there before. I checked the brake pad lining and there isn't as far as I know any junk stuck between the pad and rotor before or after the repair work was done. Can't figure out where those two small grooves came from or what might be causing this sqeak when turning issue.
Thanks for any help
nclibra1985 is offline   Reply With Quote
Old 11-12-2009, 06:54 PM   #2
Re: Squeak/grown while turning
fyi...the car is now at the dealership. my husband didnt push the wheel bearing in all the way and it messed up the hub and rotor. so now it will need new everything on the front.
Old 11-12-2009, 11:10 PM   #3
camo auto
EdDo's Avatar
EdDo is on a distinguished road
that sucks. how much did it set you back??
EdDo is offline   Reply With Quote
Old 11-13-2009, 04:04 PM   #4
$500 total. It's a mistake that will never happen again. From now on it goes to the dealership first.
Old 11-20-2009, 06:56 PM   #5
www.ScionApocalypse.com
Just1n's Avatar
OH.. FAIL! lol j/k
Old 11-20-2009, 07:22 PM   #6
XB05's Avatar
i bet thats wrong with my xB when i turn to the left it makes a roaring noise if i cut it hard! what do u think?
XB05 is offline   Reply With Quote
Old 11-20-2009, 07:40 PM   #7
it might be a lion. jk.
Old 11-28-2009, 06:48 PM   #8
ocxb's Avatar
ocxb is on a distinguished road
I have the same noise too grrrrrr while turning left and a grr grr grr while turning right... It's gotta be the wheel bearings too.
ocxb is offline   Reply With Quote
Old 11-29-2009, 05:44 AM   #9
gravebox's Avatar
takes some "oomph" to get it right. ALOT of grease too... i've seen a good number of bearing jobs that haven't used enough grease.
as for your rotors, highly doubt an improperly done bearing job would ahve put those grooves in there. could be that he didnt clean the rotors off of any break dust before putting the new pads on. so dust between the pad and the rotor can consolidate into very small pearel like debris pieces between the pad and rotor and with enough pressure can cause that to happen. also, any iron based small rocks from the road getting stuck between the pad shoe and the rotor can do the same thing as it grinds to a dust.
Old 12-05-2009, 10:16 AM   #10
crxgames's Avatar
Mine is going under wheel bearing surgery today. -.-
I hope it's not as much of a pain as a lot of people are saying.
Time for Brake pads already?
Page generated in 0.25609 seconds with 13 queries
