Old 05-03-2009, 03:50 PM   #1
JDM Fan
mikesbluexb's Avatar
mikesbluexb is on a distinguished road
Rear disc brake conversion?
Hey does anyone know of a potential donor for a rear disc conversion? Maybe the echo or prius? Im getting tired of the ugly little drums.
mikesbluexb is offline   Reply With Quote
Old 05-03-2009, 04:35 PM   #2
It's a lifestyle.
crxgames's Avatar
Re: Rear disc brake conversion?
Micro Image : Yaris Rear Disc Brake Conversion Kit
And I don't think the echo/prius has rear discs. The ae86 gts brakes have been made to work before, so have 240sx rear discs.
Old 05-03-2009, 04:43 PM   #3
Suspension Whore
859Toaster's Avatar
^and Cody and I have a source to find out if there is a swap available for our cars to run a 11" rotor up front hehehe.
Love having friends that work for dealers.
Old 05-03-2009, 05:01 PM   #4
potatoe_chips's Avatar
potatoe_chips is on a distinguished road
so does any one know if their is a donor?
this is intresting
potatoe_chips is offline   Reply With Quote
Old 05-03-2009, 05:21 PM   #5
adam_a's Avatar
adam_a is on a distinguished road
these will bolt up on the xb????
adam_a is offline   Reply With Quote
Old 05-03-2009, 08:40 PM   #6
JDM Fan
Those Yaris discs are nasty! But shouldnt it just take another Toyota's rear discs as long as its bolt pattern is 4:100? I wouldnt think that they would be too hard to swap in. (Man the Honda guys have it easy in this department...)
Old 05-03-2009, 08:51 PM   #7
Suspension Whore
859Toaster's Avatar
A simple toyota to toyota swap isn't ever going to happen. You can't take a xB2 suspension (which has rear disc) and put it on a xB1. Dimensions are way different, and the xB1 runs a solid axle.
What Cody linked you to is the kit for a Yaris. It is unknown if it will be a direct bolt on for the xB1. The only way to tell is to either 1: Try it. 2: Do a lot of spec measurements and compare the two.
Old 05-03-2009, 09:19 PM   #8
ogerdgonz's Avatar
Most of the bolt on kits out there lack emergency brake or are $1000.
Old 05-03-2009, 09:32 PM   #9
Suspension Whore
859Toaster's Avatar
Yeah, so wtf? Ad placement much?
But anyways, next time my friend Fred is around, I'll have him grab me the bracket from his work, and I'll see where it lines up at on our cars. We can run a lot of easy to get parts because of what they are from, and they aren't too pricey for a stock/oem replacement.
As for the rear, my friend Matt who is an engineer for Toyota can't really help me at all for xB stuff. He doesn't handle the xB since it is a 100% Japan car But I'll see what kind of info he can get me for the Yaris.
Old 05-03-2009, 10:25 PM   #10
The one and ONLY
gothbox's Avatar
there was/is a guy in middle Tn I think that was making kits for the rear at one point. He had a big build up over on the other site, and was using all Toyota parts, and a few custom brackets etc.
I will try and find the topic.
Old 05-03-2009, 10:29 PM   #11
Suspension Whore
859Toaster's Avatar
^Scikotics member if I am not mistaking....
I remember something about Harley Davidson parts, or he worked in a Harley shop.... It had something to do with Harley. It may be on here as well.
Old 05-03-2009, 10:37 PM   #12
The one and ONLY
gothbox's Avatar
yeah thats the same guy I am thinking of.
I don't remember any Harley stuff, but I stopped following after a while.
Old 05-03-2009, 10:37 PM   #13
It's a lifestyle.
crxgames's Avatar
You are thinking of rcurry. Not sure what happened to him.
Old 05-03-2009, 10:40 PM   #14
Suspension Whore
859Toaster's Avatar
^bustin out the Rolodex? lol
Old 05-03-2009, 11:13 PM   #15
JDM Fan
Well, thanks for the info guys. I have seen the Willwood oversized kit for all four corners. It retails for close to $2000 so I wanted to go about a cheaper alternative.
Old 05-03-2009, 11:24 PM   #16
The one and ONLY
gothbox's Avatar
Old 05-03-2009, 11:33 PM   #17
Suspension Whore
859Toaster's Avatar
Do you're research.
When we did it to Cavaliers (88-05's) we were using Neon rear disc. Its all in finding what works. Cavaliers had solid rear axles as well.
Old 05-04-2009, 12:41 AM   #18
JDM Fan
Thumbs up Re: Rear disc brake conversion?
Thanks for that link Gothbox. I am optimistic, it looks like its possible. There probably isnt enough demand for a mainstream kit. I would buy one though. If it can be done on a Cavalier solid axle, it can on an xB1 too.
Old 05-04-2009, 01:20 AM   #19
Old 05-04-2009, 02:02 AM   #20
ogerdgonz's Avatar
The corolla set up never got the emergency brake working if I remember right.
Body Drop on 20's
Page generated in 0.28579 seconds with 13 queries
