Old 10-15-2009, 11:33 PM   #1
felixy69 is on a distinguished road
Q's about air suspension RIDE QUALITY !!
i have front and rear uair aerosport and airhouse 2
at 55psi ish.....it gets me the preferred height..but the ride quality totaly sucks...i am bouncing all over the place and even have trouble putting pedal down..cuz i am bouncing off the throttle....
are air ride suppose to be like this ?
i am using MEGAN COILOVERS along with these bags ..
felixy69 is offline   Reply With Quote
Old 10-15-2009, 11:53 PM   #2
The OG Super Mod
ScottyTuned's Avatar
Re: Q's about air suspension RIDE QUALITY !!
Dont you have a Fit though? Or do you have an xB too? I dont know if that will change things since the suspensions are different.
Old 10-16-2009, 05:51 PM   #3
Suspension Whore
859Toaster's Avatar
so are you using the EZ bag conversion on Megan struts?
First off, your dampening is probably too stiff. Turn it down.
Or if your using the Megan coil bag thingy's, change the height of the strut. Make them longer, so you can ride with lower PSI. But 50psi should be rather smooth.
Old 10-16-2009, 05:58 PM   #4
Never Stops
Digidizzle is on a distinguished road
Send a message via AIM to Digidizzle
Damn! I run about 10 psi in the rear for my UA bags. 50 would have me at 4x4 status!
Digidizzle is offline   Reply With Quote
Old 10-16-2009, 09:07 PM   #5
Suspension Whore
859Toaster's Avatar
I prefer 0 on all 4 corners. But it takes work to be able to drive at 0 psi on any car.
Old 10-17-2009, 04:07 AM   #6
ogerdgonz's Avatar
1X 380C vair
2 3gallon tank
universal air coil bag front W/ megan coilover (modifications to the legs to go lower)
universal air air house 2 rear with custom brackets
and done some modifications to the rear suspension swing arm to clear the bags,
This is his air ride set up on his fit....... I am going with you have the dampening set too stiff on the coil overs. Also maybe raise the coil over up a little and run less air pressure.
Old 10-17-2009, 12:36 PM   #7
Suspension Whore
859Toaster's Avatar
Originally Posted by ogerdgonz View Post
1X 380C vair
2 3gallon tank
so minus stating what his set up is, you just said the same thing I did.
Old 10-17-2009, 05:42 PM   #8
no_lines's Avatar
i cant run 0 psi i drag to much even when i run maybe 5 or 10 psi i pick up so many pebbles on the dang road
Old 10-18-2009, 03:59 PM   #9
Lowest xA on air
LayedoutxA's Avatar
LayedoutxA is on a distinguished road
You can' drive at 0psi unless you are just dragging to show off.
I ride mine 1 1/2 inch off the ground, front and back.
LayedoutxA is offline   Reply With Quote
Old 10-18-2009, 10:38 PM   #10
i have a ? it isnt about the ride quality bc everytime i post a thread it gets closed so ill put it here! im just wanting to know who should i take my xB to for my air suspension i want someone who is definetly going to do it right and not half assed is there anymore shops in ky(besides cool cars bc they currently arent doing any installs),tn area ?
XB05 is online now   Reply With Quote
Old 10-19-2009, 03:25 PM   #11
Suspension Whore
859Toaster's Avatar
Its all bolt on unless you go with the Universal Air set up. xb05.
CCE is a good place to go... But try to find a company called Fat Man Fabrications. AKA Big Vic. He has a C10 with 1" valves and shit is legit! I know a few guys that have taken their trucks to him for body dropping, 6link installs, ect ect. Man does great work. He's based out of Louisville I think. So no further than CCE.
Old 10-19-2009, 03:42 PM   #12
hell yeah sounds dope already ill check them out i know they do alot of hydraulics n shit n as much as ive seen it looks like they know what the hell they r doing
but ill check out fatboy fabrications i mean
Old 10-26-2009, 12:59 AM   #13
Suspension Whore
859Toaster's Avatar
Originally Posted by dethbox View Post
im on ua aeros and air house 2s with monroe echo shocks and struts and i ride the front at 50psi and the rear at about 15 and the ride is unbelievably smooth. and im on 18s with 35 series tires stretched.... so ya check your dampening. also try running a little higher pressure in the front and less in the rear. for some reason when i was on steelies that was smoother for me.....dont know y
That's simple. 15" steelies with bigger tire. (height wise). The side wall of the tire has more give or cushion to it. The 18"s are low profile. The sidewalls are extremely stiff. They tend not to have any or very little give to them to protect the rim, and to keep the tire from getting pinched in the rim and being blown out, cut, or punctured.
Just remember the term for a heavy woman... More cushion for the pushin!
Oh and with your tires stretched... Even MOAR stiff. Drift cars run the stretched tire for this reason. Not for the look believe it or not. It makes the sidewall even stiffer, and prevents sidewall flex. Which is a enemy of going slideways.
Old 10-26-2009, 02:19 AM   #14
actually my coilover have 36 way adj.
1 being soft and 36 being stiff
i am at 10-15 right now
if i turn it all the way to 1 or any softer then wat it is now....it would be super bouncy
ugh..dunno wat to do...may be my shock sucks
Old 10-26-2009, 09:47 AM   #15
Suspension Whore
859Toaster's Avatar
Raise the perches so you can change the amout of air for desirable lift. 30 to 40 pounds should be ideal for about any car.
Old 10-29-2009, 03:04 PM   #16
then i wouldnt go as low as i go now....
Old 10-29-2009, 04:43 PM   #17
Suspension Whore
859Toaster's Avatar
Then don't complain about the ride quality.
With a set up like yours it goes one of two ways.... Comfort, or Stance. Unless you build a cantilever system in the rear, and a fully custom front, you're not going to get the both of both worlds. Look at Gothbox. He's lost a lot of the comfort features of his cars suspension to get low. Price you gotta pay.
Body Drop on 20's
Page generated in 0.42243 seconds with 13 queries
