Sorry I haven't been on here in awhile so I didn't update on this. Well it was a PITA to pull everything apart and I ended up having to buy a new axle. I heated the hell out of the nut 4 times and broke 2 socks getting the nut off.When it was put on at the factory they must have stripped out the threads on the shaft cause that ended up being the problem with getting the nut off.
I took the hub into work and had the machinist press the bearing off. It wasn't even bad.
So I repacked it with wheelbearing grease and had him press it back on. I was going to change it anyways but Advance Auto's bearing was to narrow. The original bearing is like 2" wide.Theirs is about an inch so it wouldn't work. Make sure you get the right one before you leave.Anyways I ended up putting everything back together to find out it was brakes that were hanging up and heating up my rotor.
I pulled the pins and antiseazed everything to keep it all moving.I also cleaned up the ears on the pads and antiseazed those also to get then sliding smoothly. Haven't had a problem with that side since.Now the Passenger's side decided to start it.
I cleaned it up today but I got something rubbing so I have to pull it apart again. Be sure it isn't your brakes before you go spending all the money on wheelbearings. A mechanic friend of mine said you can drive a long time with a bad bearing on import cars do to the way the bearing is made.
Originally Posted by Black_Box can you buy the parts preassembled...i think my front bearings are going...i hear clicking while im driving. |
Rears can be bought preassembled but the fronts have to be pressed out and new ones pressed on.The clicking could be your CV joint not your bearing.I'd start there first.
Originally Posted by Black_Sheep_xB yeah.. wheel bearings on an American truck are different than doing these. On a Chevy they basically fall out.. tight tolerance, press fit, imports.. not so much. |
Alot of american cars you can buy the whole assembly cause they are bolted in instead of pressed on.
Originally Posted by nclibra1985 omg...my husband just did my front left wheel berring today and it took over 6 hours! he also broke 2 wheel berrings and just about tore up some other parts. this is the worst job ever and i honestly cant wait to get a different car so its easier to work on.  |
Good luck with that. Most newer cars are just as hard to work on if not harder. I'll stick with my box.
