Old 08-10-2008, 04:41 PM   #1
morningman is on a distinguished road
i need a shock shorter than a 5870
ok i need a shock that is shorter than the monroe sensatrac 5870
with my bags i am bottoming out the 5870 so if anybody has the any positve insight on this it would be greatly apreciate it
Thanks
Lil Dave
morningman is offline   Reply With Quote
Old 08-10-2008, 08:17 PM   #2
thats Reverend ^^
gothbox's Avatar
Re: i need a shock shorter than a 5870
I am using a shock for a 03 Toyota Sienna van, part #37243
they don't go as high either, so the back is actually level with the front all the way up.
Old 08-10-2008, 09:38 PM   #3
awsome i appreciate it man
Thanks
Lil Dave
Old 08-10-2008, 09:41 PM   #4
thats Reverend ^^
gothbox's Avatar
sure man, no prob.
Old 08-10-2008, 10:22 PM   #5
simijoecool's Avatar
is 5780 the one for the echo? if not perhaps try there. but wow the sienna? how did u find that?
Old 08-10-2008, 10:26 PM   #6
thats Reverend ^^
gothbox's Avatar
somebody else had did a ton of research and figured it out. I am just passing along the info.
Old 08-11-2008, 08:22 AM   #7
Eav10xB's Avatar
Are those sienna once as cheap as the Echo ones? The Echo ones are like 30 bucks a pair for the rear and 68 i believe a pair for the front.
Eav10xB is offline   Reply With Quote
Old 08-11-2008, 08:33 AM   #8
thats Reverend ^^
gothbox's Avatar
depends on where you go, and what brand you get.
I think I paid like around $40 for mine, but I don't remember what brand I bought.
Old 08-11-2008, 10:06 AM   #9
i did a little more resear and found this out
Model # Extd. Compressed Travel
5870 23.8" 14.25" 9.6"
5854 20" 12.12" 7.8"
5867 19" 11.75" 7.25"
Old 08-15-2008, 11:42 AM   #10
no_lines's Avatar
idk if the 5870 has the 23.8 and the 5867 has a 19 it probley wont be level when u air up, but thats just my guess
Old 08-15-2008, 12:32 PM   #11
Eav10xB's Avatar
Echo shocks or Sienna shocks? Item numbers? Which one is best for Tanabe 210's? I am not on air, I am looking for a replacement shock that is shorter than our stockies, also that has a nice comfortable ride for passengers, because right now it is nice and stiff and bumpy.
Old 08-15-2008, 12:48 PM   #12
Big_Kokujin's Avatar
the echos only lower in the front.
Old 08-15-2008, 10:51 PM   #13
thats Reverend ^^
gothbox's Avatar
if you are just doing springs and no air, then the 5870 will do great. That is what I am running on my other box, with springs and it rides better then stock.
Old 08-18-2008, 08:15 AM   #14
Eav10xB's Avatar
Thanks, I just need something shorter in the rear because the rears do not have any traveling space right now so it is stiffer than hell.
Thanks.
Old 08-18-2008, 08:17 AM   #15
But those will not make it lower, only ride better.
Old 08-26-2008, 04:41 PM   #16
www.ScionApocalypse.com
Just1n's Avatar
I was going to say the same
5867 19" 11.75" 7.25" <----randode's pick
Old 08-26-2008, 08:39 PM   #17
no_lines's Avatar
if u use the 5867 watch out if your mounts let u go that low you might want a 4 link, im on stock shock's n my axle housing is hittin fuel lines
Old 08-26-2008, 08:45 PM   #18
crxgames's Avatar
You could always get a set of monroe air shocks. I forget the part number, but they are like $68 from pep boys and they go quite low. I haven't personally tried them, but quite a few of the bb squad guys have.
Old 08-26-2008, 08:48 PM   #19
859Toaster's Avatar
But are they running them with bags?
Because air shocks tend to hold weight of vehicle pretty well. So you'd have to dump your shocks and bags at the same time, and same speed (or close if you don't want the strange dump/fill).
I think we talked about this before Cody
Old 08-26-2008, 08:53 PM   #20
crxgames's Avatar
Yeah, a few with air tried it. Some of them even have them on their own fill system iirc. Afaik most set them to the lowest point they want. If you want more info hit up the site. I'm by no means an expert on it, just rehashing what I've read.
Time for Brake pads already?
Page generated in 0.32946 seconds with 13 queries
