Old 02-15-2009, 10:46 AM   #1
IloveSpeedbumps is on a distinguished road
I cant find the noise!!
So I know i need brakes, but i believe this is a diff noise. When i turn left i get a loud scrubbing noise. Its not the tire hitting anything(i have no fender liner and its the same noise slammed or aired up). Its more of a metal on metal noise. I did some research and it could be the wheel bearing. Toyota wants 400 to fix that. During my searches i also learned the wheel will move when you jack up the car and shake it, mine doesnt.
Any ideas on what else it could be? Im still leaning towards a front wheel bearing, i just want to be sure before i shell out the 400 bucks.
IloveSpeedbumps is offline   Reply With Quote
Old 02-15-2009, 10:49 AM   #2
bB Squad
JDM_Imperial_bB's Avatar
JDM_Imperial_bB is on a distinguished road
Send a message via AIM to JDM_Imperial_bB
Re: I cant find the noise!!
check your bearing, ball joints and also your cv axles... both my cv axles went bad and didnt get the usual cracking sound
JDM_Imperial_bB is offline   Reply With Quote
Old 02-15-2009, 12:00 PM   #3
thefonz's Avatar
thefonz is on a distinguished road
I know this sounds dumb but sometimes the wear indicator on the brake pad can cause this noise even when the brakes arent applied. (LIKE I SAID, sounds dumb). If you need brakes just change them and while your wheels off look around. Might see something.Noise might go away after pad replacement. GL
thefonz is offline   Reply With Quote
Old 02-19-2009, 05:38 PM   #4
UPDATE....it was the wheel bearing. I had it replaced and all is well again!
Old 02-20-2009, 01:21 PM   #5
raceking924 is on a distinguished road
Send a message via AIM to raceking924
ah heck...im hearing a noise too (sounds like metal on metal as well)...please god dont tell me its a wheel bearing...ugh. i thought at first it was the 3 heads on the top of the strut not being locked down making the sound when the car goes up and down(kinda like a grinding) but theyre secure. im going to go cry in the corner now...brb.
raceking924 is offline   Reply With Quote
Time for Brake pads already?
Page generated in 0.16136 seconds with 13 queries
