Old 03-13-2006, 08:57 PM   #1
iheartmyxb's Avatar
iheartmyxb is on a distinguished road
Send a message via AIM to iheartmyxb
how to install???
hey guys i just got some Progress Lowering Springs how hard is it to install them?
? could u guys kind of give me directions on how to do it? thanks
iheartmyxb is offline   Reply With Quote
Old 03-13-2006, 09:32 PM   #2
Fronts are the only difficult ones because of the struts, the backs are cake!
With out the correct tools I'm not sure how others are doing the fronts.
I work at a shop, and have the right tools on hand. Wall mounted spring compressor, etc. took me about 45min to do all of them. 30 on front 15 on back.
Old 03-13-2006, 09:39 PM   #3
iheartmyxb's Avatar
alright thanks bro b ut like how do i do it?
take off the wheels.. and i dont know from there =/
just now starting to work onmy car and i dont want to **** it up.
Old 03-13-2006, 09:40 PM   #4
I didn't use a spring compressor on the fronts, and used the old school towels in a box to cushion the strut method. It doesn't actually travel that far considering the length of the spring. An hour total time at the most w/ hand tools. The rear only takes a few minutes. Just unbolt the shock at either end, jack up the car, and let the springs fall out.
Old 03-13-2006, 09:41 PM   #5
iheartmyxb's Avatar
alright thanks alot guys.
Old 03-13-2006, 09:44 PM   #6
Pitman's Avatar
Pitman is on a distinguished road
Dude springs are no problem if you have a bit of mechanical ability and the right tools. I've done numerous suspensions and the xB is one of the easiest 45min job. Here's what you need:
Ratchet
17mm socket (top strut nut/rear shock nut)
12mm box wrench (top strut mount nuts)
19mm socket (strut to spindle bolts/nuts)
14mm socket (brakeline bracket bolt)
spring compressor
Floor jack/jack stands
2 new top strut nuts
Time
Now the thing is do you have any mechanical abilities?
or
Maybe one of the guys in your area who has done these can give you a hand
I just did a guys here in SC this past weekend
or
If you have any question as to your abilities...........pay a shop to do it.
There is nothing wrong with paying for a bit of "peace of mind"
Peace
Pitman is offline   Reply With Quote
Old 03-13-2006, 09:45 PM   #7
I can tell you how to do the back.
Jack the back up, put jack stands on the outside rails.
Pop the little covers off the tops of the strut towers in the back hatch.
Remove the two nuts on each side, the shocks and rear axle will swing down towards the ground, remove the springs, slide in the new ones. Jack the rear axle and shocks back up into the mounting holes and put the nuts back on. I don't know the top from the bottom of the springs that you have, so I don't know which end goes up.
Old 03-13-2006, 09:46 PM   #8
iheartmyxb's Avatar
Ratchet
spring compressor
Time
or
or
Peace
thanks alot my 2 friends are gonna help me and they lowered a accord and civic and some other cars before so they said they help.
Old 03-13-2006, 09:48 PM   #9
iheartmyxb's Avatar
do i really need 2 new strut nuts?
i didnt get them wit the springs.
Old 03-13-2006, 09:52 PM   #10
Pitman's Avatar
Not really I would bet that most guys don't replace them. But for a few bucks might as well ........these are not nylon lock nuts they have "gills" on the bottom that act as a locking mechanisim after one use they can "wear down" and might not be as affective ............but with that said......it's up to you. it is recommended however.
Peace
Old 03-13-2006, 09:54 PM   #11
I didn't initially replace my strut nuts, but did after they kept loosening on me. It stop that problem.
Old 03-13-2006, 09:55 PM   #12
iheartmyxb's Avatar
Peace
alright htanks where do u think i can get some and for about how much? im kinda way low on cash i just bought wheels and springs so i dont really have money to be spendin.
Old 03-13-2006, 10:02 PM   #13
Pitman's Avatar
Local Toyota dealer,........... don't know how much but I'm sure you can find some change laying around to pay for them. Maybe a couple of bucks. Mine came with my coilovers and before that I didn't replace them when I first put my S.Techs on. The guy's I just did last weeekend got them from the dealer here don't know how much he paid, sorry
Old 03-13-2006, 10:04 PM   #14
iheartmyxb's Avatar
oh ok i mean i have some cash but not to much.
Old 03-17-2006, 09:58 AM   #15
Skeeter's Avatar
It took me an hour at a freinds shop with all the air tools and wall mounted spring compressor. The tools make the job easy.
Old 03-17-2006, 08:54 PM   #16
Frogbox is on a distinguished road
When I changed out my springs had my son and his friend helping, did it in about 1 hr and 20 min start to finish.
used spring compressor bought for the job.
If I can do it with help, anyone should. But if your not comfortable doing it get a friend that knows to help.
Frogbox is offline   Reply With Quote
Old 03-17-2006, 09:14 PM   #17
mORON mODERATOR
Cravin's Avatar
On the front struts I was planning on using a few heavy zip ties to hold the coils when the car's weight is still on the springs. Then after I jack it up the coils will still be compressed somewhat making it easier to dissasemble the strut. Thats my plan anyways.
Cravin is offline   Reply With Quote
Old 03-21-2006, 01:51 PM   #18
hotbox05's Avatar
i can lower xb's/ xa's on springs in 45 minutes or less guarranteed , i've done it about 50 times . my fastest yet was 20 minutes .
with nothing but hand tools.
Old 03-21-2006, 02:33 PM   #19
Pitman's Avatar
hotbox..........20min come on man!!.........it's 5-10min just to jack up take off front wheels .......reinstall wheels. then off the jack. That is with all hand tools and 1 jack, no lift etc. Now if you had a lift and air tools then I can see 20 min. but ALL HAND TOOLS.. NO WAY 20 min. sorry bro! I've been doin suspensions for 15years ,......raise, lower, struts, springs, torsion bars, whatever. By myself busting my a@@ all hand tools..... I could probably do 30 min. I mean the rears are what 2min maybe. But the fronts unless your a cowboy and don't compress the springs when you take them off, the fronts are 10 min a piece done right. I don't mean to be a spoiler but PLEASE!
Peace!!
Old 03-21-2006, 03:12 PM   #20
the brave little toaster's Avatar
the brave little toaster is on a distinguished road
Send a message via AIM to the brave little toaster
i can do it about 30 min but i had have air tools and compressor.
the brave little toaster is offline   Reply With Quote
...alarm recommendations & install South OC xBMoDee South West 3 10-13-2007 01:19 AM
headlight install mplayboy72 Scion xB Lighting & Electrical 9 10-18-2006 04:29 AM
Help with project lights install randkgifts Scion xB Lighting & Electrical 1 06-08-2006 02:44 PM
Stereo install question fcastle Scion xB Audio, Video, & Security 5 03-06-2006 01:15 PM
How To Install An Ipod In A 2005 Scion Xb Using The Aux-pod From Pac-audio admin Scion xB Audio, Video, & Security 0 02-26-2006 02:07 PM
Time for Brake pads already?
Page generated in 0.30569 seconds with 14 queries
