10-06-2008, 04:01 PM
| how bad is it to run lowered springs with stock shocks? will my shocks give out quick? What kind of problems could i see in the near future? |
10-06-2008, 04:04 PM
#2 | | 2006.5 TCM
| Re: how bad is it to run lowered springs with stock shocks? I've put about 30K miles on mine since installing H-Techs with no problems. But that's the mildest drop springs you can get.
May also depend on the weight of your wheels/tires and sidewall. |
10-06-2008, 06:41 PM
#3 | | The OG Super Noob
| Re: how bad is it to run lowered springs with stock shocks? my car had 45k when i put on Spy springs (big drop, around 2.75in)
it has 51k now and i am replacing the shocks/struts because its too bouncy IMO |
10-06-2008, 07:14 PM
#4 | | swangin 4rm lane 2 lane
| Re: how bad is it to run lowered springs with stock shocks? I ran my df210's and stock shocks 4 about 10,000 miles wit no problems |
10-07-2008, 10:15 PM
| Re: how bad is it to run lowered springs with stock shocks? Changed my stockers out to KYB GR2 Toyota Echo struts and got another 1/2" of drop. |
10-07-2008, 11:08 PM
#6 | | Suspension Whore
| Re: how bad is it to run lowered springs with stock shocks? You should NEVER put lowering springs on STOCK struts.
I yell at CRXgames all the time for buying the UAS air ride kit. Because that requires you to use the stock struts to mount the bags. |
10-07-2008, 11:16 PM
#7 | | Yakima Rack God
Join Date: Dec 2005 Location: in a house, on a street, in a city, that is located in a state somewhere !!
| Re: how bad is it to run lowered springs with stock shocks? you should not, but you can. I am going on 45xxx miles on my stockies, and have not seen any issues yet. But I did have mine revalved when I dropped it, to compinsate for the drop. |
10-08-2008, 12:35 AM
| Re: how bad is it to run lowered springs with stock shocks? I am dropped on goldlines which are way low. tried to run the stock shocks for about a minute... every bump was torture, slamming to the deepest depth of the stockies. Tossed some monroes on the rear & now my only problem is my dc exhaust whacking the ground over the same bumps. I just cant win.
To answer you question, you CAN get away with it depending on your drop springs, but if you got the cash, since you got it pulled apart anyway, you might as well drop the extra few bucks in & do it right the first time rather than having to pull it apart again later.. |
10-09-2008, 03:18 PM
| Re: how bad is it to run lowered springs with stock shocks? thanks guys this really helped
and im getting df210s and will probably run those monroe's |
10-09-2008, 03:24 PM
#10 | | AirSquared
| Re: how bad is it to run lowered springs with stock shocks? i have already replaced my stock shocks with monroes and i think they are starting to go as well! of course im bagged, so they get to see a heck of alot more travel than just your ordinary dropped box. but definitely get the monroes....very nice ride to them! |
10-09-2008, 03:31 PM
#11 | | Suspension Whore
| Re: how bad is it to run lowered springs with stock shocks? ^^what do you expect driving on 0PSI with the concrete as your shock? lol |
10-09-2008, 03:33 PM
#12 | | AirSquared
| Re: how bad is it to run lowered springs with stock shocks? well, life begins at 0 PSI (at least in my world it does). and im sure the drag blocks arent helping the situation at all!! oh the joys of being bagged and daily driven! |
10-09-2008, 04:46 PM
#13 | | Suspension Whore
| Re: how bad is it to run lowered springs with stock shocks? Quote:
Originally Posted by jx1379 well, life begins at 0 PSI (at least in my world it does). and im sure the drag blocks arent helping the situation at all!! oh the joys of being bagged and daily driven! | LOL! INDEED!
Good times to be had at concrete level... I miss those times. lol |
10-09-2008, 05:02 PM
#14 | | It's a lifestyle.
| Re: how bad is it to run lowered springs with stock shocks? ^ I need to get some blocks so I can join the concrete basement club-o-fun. |
10-09-2008, 05:07 PM
#15 | | AirSquared
| Re: how bad is it to run lowered springs with stock shocks? silverstarcustoms.com - 50 bucks will get you some sweet titanium blocks w/bracketry! |
10-09-2008, 05:09 PM
#16 | | It's a lifestyle.
Originally Posted by jx1379 silverstarcustoms.com - 50 bucks will get you some sweet titanium blocks w/bracketry! | May have to do that. I still need to hack my rear brackets to get the back lower. May get an H-brace for dragging up front though. Now that I'm sitting on the swaybay that should do it. |
10-09-2008, 08:06 PM
#17 | | i have come for the BOOTY
| Re: how bad is it to run lowered springs with stock shocks? almost 65k miles on stock shocks with s techs with 2 coils cut off of them with no problems!! |
10-09-2008, 11:01 PM
#18 | | Registered User
| Re: how bad is it to run lowered springs with stock shocks? was on s techs and stocks for close to 50K and thoes were hard miles, TRUST ME. now i'm on monroe sensatracks for the echo. |
10-10-2008, 05:25 AM
#19 | | Registered User
| Re: how bad is it to run lowered springs with stock shocks? Running stock shocks/struts with S-techs. No problems. |
10-14-2008, 12:54 AM
#20 | | letzzzroll
| Re: how bad is it to run lowered springs with stock shocks? just got a pair of sprint springs and they all have a coil cut off and the drop is allready supposed to be low as shit....
will i be ok w/ stock struts?  |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | | All times are GMT -5. The time now is 01:57 AM. |
