Old 02-22-2006, 12:14 AM   #1
Flecs's Avatar
Flecs is on a distinguished road
front strut bars??
ok... so im in the process of making a front strut bar in my metals class
i am wondering how you go about installing a strut bar on the xb
there seems to be little room there... me and my friend went about taking out all of the plastic and the windshield wipers only too find that there is still alot of metal there anywayz and it would be a PITA too take all of that stuff out aswell
so if someone could please tell me how one would go about installing one it should help me alot in the building of one
or if you know of a tut on like SL or somthing that i missed.... you could just post a link to that too i guess
Flecs is offline   Reply With Quote
Old 02-22-2006, 12:55 AM   #2
It's not as hard as you might think. Loosen all the strut mounting nuts and when you can't turn the back ones any further jack up the front end just enough to let you push down on the front wheel. Push down until the bolt for the strut begins to go down and remove the nut. Place the strut bar mount on the strut tower and reverse the process. You will find that using an open end wrench on the back nuts will be easier than trying to get a socket on there.
When you're done it should look something like this:
I hope that helps. If it's not clear enough let me know and I'll answer more specific questions. My installation took a total of about an hour including adjusting the bar. Good luck and happy modding.
Try this DIY: http://www.scionlife.com/forums/viewtopic.php?t=29717
front strut bars, what kind do you have? smalltownscionman Scion xB Suspension, Chassis & Brakes 130 06-05-2009 09:31 AM
Front bumper fix. Gcat007 General Scion xB Discussion 15 02-22-2006 09:19 PM
WTB: Cusco OS Strut Bar kool b Wanted Scion xB Parts and Vehicle 8 01-24-2006 11:30 PM
Does a Strut Bar Help ? daramg Scion xB Suspension, Chassis & Brakes 11 01-16-2006 04:59 PM
Front sway bar questions Ghost_1 Scion xB Suspension, Chassis & Brakes 11 01-10-2006 07:45 PM
Time for Brake pads already?
Page generated in 0.42385 seconds with 140 queries
