Old 11-20-2007, 03:37 PM   #41
BATComm1's Avatar
BATComm1 is on a distinguished road
Send a message via AIM to BATComm1
Re: Easy Street Easy Camber Fix
Anybody on here tried the Chassis Tech front struts...you can get them at airbagit.com...they are 899.00 for the set...just wondering..
BATComm1 is offline   Reply With Quote
Old 11-29-2007, 11:41 AM   #42
Often Imitated
randode's Avatar
I have them.
Here's the pros and cons:
Pros:
uses a double convoluted bag (gives a nice ride due to the large air volume).
Cons:
They clunk and make all kinds of horrible noises when lifting.
The shock inside is crap. It's chrome (ooohhh, ahhh) but crap quality. With the strut unloaded I can knock the top of the tire in and out.
You have to grind the bottom bracket of the strut to clear the CV boot.
You have to grind some of the casting down on the spindle so the strut bracket fits.
If you still decide to go with the CT struts, take them completely apart and reassemble them with loc-tite before you install them. A buddy of mine had several of the small bolts that hold the bag to the aluminum bracket fall out. This caused a major air leak.
randode is offline   Reply With Quote
Old 02-06-2008, 03:37 AM   #43
The one and ONLY
gothbox's Avatar
gothbox is on a distinguished road
did this fix yesterday, took a little longer then you Randode, cause all I had was a Dremel with a grinding stone. But got it done, and now have a little neg camber when aired out.
Now all I need to do is order the rear brackets.
Thanx for the help Randode.
Old 02-06-2008, 11:44 AM   #44
Often Imitated
randode's Avatar
a Dremel? holy balls. i bet that took forever.
Old 02-06-2008, 02:56 PM   #45
The one and ONLY
gothbox's Avatar
yea it did, about 20min each hole. But thats all I had and was determined to do this.
Old 02-07-2008, 01:54 PM   #46
The one and ONLY
gothbox's Avatar
here is a before and after pic, now I can actually run my fingers inbetween the tire and fender.
Old 02-16-2008, 01:23 AM   #47
mrmcnuggett's Avatar
mrmcnuggett is on a distinguished road
I have got to get some cahones and do this. I am tired of my tires wearing out.
mrmcnuggett is offline   Reply With Quote
Old 09-29-2008, 11:10 AM   #48
www.ScionApocalypse.com
Just1n's Avatar
bump......
Old 10-06-2008, 12:03 PM   #49
Big_Kokujin's Avatar
Randode, are the pics swapped? I mean would + camber make the bubble on the lever closer to the inside and - make it closer to the outside?
Old 10-06-2008, 12:34 PM   #50
moonray's Avatar
No the pictures are correct. Positive camber moves the bubble outward, negative camber inward.
Old 10-06-2008, 01:10 PM   #51
I dont understand how. negative camber will make the outside higher, wont the bubble go to the higher side?
Old 10-06-2008, 01:19 PM   #52
Often Imitated
randode's Avatar
after looking at page 1 again, i think the pics are in the wrong order.
positive camber would make the bubble on the inside
negative camber would make the bubble on the outside
Old 10-06-2008, 02:05 PM   #53
Just checking so no one made their + camber worse.
Old 10-06-2008, 02:08 PM   #54
moonray's Avatar
Sorry -- Never mind what I just posted -- Dooohh -- Holy crap my mind is failing me!!!!!
Old 10-06-2008, 04:14 PM   #55
iceboxx5 is on a distinguished road
Hey randode!!! can you just make a front kit for the gen 1 so we can stop wasting money on crap.
iceboxx5 is offline   Reply With Quote
Old 10-06-2008, 06:11 PM   #56
Often Imitated
randode's Avatar
yes.
the Randode Air Stunner
Old 10-06-2008, 06:18 PM   #57
The OG Super Mod
ScottyTuned's Avatar
Price??????????
Old 10-06-2008, 06:29 PM   #58
Often Imitated
randode's Avatar
Originally Posted by ScottyTuned View Post
Price??????????
can't talk price here.
email me randode@randode.com
do you want to mod your stock struts? or would you want a complete replacement?
Old 10-06-2008, 06:34 PM   #59
The OG Super Mod
Email coming sir!
Old 10-06-2008, 06:38 PM   #60
Never Stops
Digidizzle is on a distinguished road
Send a message via AIM to Digidizzle
Looks great. I saw those on the link you sent. Looks like it came from the factory.
Digidizzle is offline   Reply With Quote
Body Drop on 20's
Page generated in 0.36350 seconds with 12 queries
