Well after my post “What springs for my xB” I made the decision to go with the Tanabe DF210s. I thought Long and Hard about the Tein S-Techs, but after measuring everything I might possible drive “Up” or “Over” I felt I could get away with the .5” Less clearance the DF210s will give me. I hope the revised saying “Measure Twice and Lower Once” will have worked. And besides I want to LOWER my car and that to me means as low as I can handle. Thanks , Buckbee23, Padanky, Toy Box 02, DarkSide xB and especially PCH for the detailed answers and the “lowered with stock shocks” and “Fake Tein” links and mojzee for the pic with wheel, tire, drop specs.
Keeping with the “Lower it once” plan. I am on to the next questions.
CAMBER / ALIGNMENT: I recognize I will need to have an alignment done.
1) Should I buy and pre-install or bring when I have the alignment done a “Camber kit”. With a drop of 2.2” Front and 2.0”. Will I need something like this:
eBay Motors: INGALLS FRONT CAMBER KIT SCION 04 05 06 XA XB 2004 2005 (item 360098071996 end time Oct-21-08 17:38:56 PDT)
Or this:
eBay Motors: SPC FRONT REAR CAMBER KIT SCION 04 05 06 XA XB xA xB (item 330279346548 end time Nov-15-08 11:34:34 PST)
2) I am not looking to get the Cambered “Squat” look, just original specs that won’t wear my tires funky on the inside. Do I need a both a front and rear “Kit” to accomplish this? If so what is the best on a budget? The above “ebay specials” acceptable?
SHOCKS: After reading the “How bad is it to run lowered springs with stock shocks” that PCH posted the link for in my other thread. I must admit I am not necessarily sold one way or the other. It does however make sense to me that the stock shocks would be designed and valved for the stock height and “Absorption Range”. So if not Cost phibitive I think I would like to do the shocks at the same time.
1) With the DF210s 2.2” Front and 2.0” and Rear drop & 157 lb. Front and 168 lb. Rear spring rates on 205/55s. Let’s hear your recommendations. I would appreciate applicable brand and model numbers if possible. Sounds like a lot of the echo Struts/Shocks are used, is that the way to go?
ESPECIALLY YOU GUYS RUNNIN DF210s!
I don’t want additional drop I think the 2.2”/2.0” will be plenty for me. Keep in mind mine is a “Box on a Budget”.
2) I read in the “How bad……Stock shocks” thread someone had stock ones “revalved” Recommended? How & where is it done? How Much $$.
3) Can I /Should I, consider Just Front Struts or Rear shocks Only?
I know A LOT of questions, But I am confident the experience and knowledge for me to “Lower it Once” is available through this forum.
Ok PCH……
