Old 07-12-2009, 09:09 PM   #1
Lifex's Avatar
Lifex will become famous soon enough
CV Joint Death
Has anyone done the work to replace the cv joints on there own? because im pretty sure this is the problem. accelerating makes the noise louder, like a thuding noise makes the car shake, turning doesn't help the noise, when i turn it sounds like rubber is being rubbed against and regardless - i kinda hope its not difficult to replace
Lifex is offline   Reply With Quote
Old 07-13-2009, 01:07 AM   #2
859Toaster's Avatar
Re: CV Joint Death
maybe if you didn't suck at life this wouldn't be an issue!
Just do what I told ya, and find the problem that way. Process of elimination.
For future newb reference, Jack the car up just enough to get wheel off ground.
Pull and push on the top of the tire. If it moves back and forth its wheel bearing.
Also you can spin the wheel with it in neutral. If you feel it binding, or hear it, more than likely a wheel bearing. But be sure to check your wear indicators on the brake pads. If the metal tabs touching that is your grinding noise!
For cv joints, they will typically pop when turning. Common issue is the boot looses its axle grease and you start killing it that way. You'll know if you loose a boot because there will be grease on the inside of your wheel. (its REALLY nasty, been there done that on the xB, and another car).
If you can't figure it out this way, take it to a qualified dealer or tech. They don't always charge you to just look at it. Better to be safe and correct, than sorry and with out your boxity box!
Old 07-13-2009, 12:47 PM   #3
Lifex's Avatar
Re: CV Joint Death
hahha i had posted this before i had asked you
Old 07-13-2009, 01:00 PM   #4
Re: CV Joint Death
Do what Stenger said. Gotta make sure it's not the wheel bearing.
Old 07-13-2009, 01:03 PM   #5
Lifex's Avatar
Re: CV Joint Death
right im going to take care of that later - i just don't have access to the tools i need and i don't get paid til wednesday so SOL until later for now
Old 07-13-2009, 03:57 PM   #6
Nor*Cal Scion Apocalypse
awinter's Avatar
Re: CV Joint Death
I had to replace my CV joint after the Cat City show. I had a rip in the boot and didn't notice that the molly grease had emptied out over time until the part finally started to die. I had terrible vibration from side to side as both the inner and outer seal were gone on the drivers side. It was very visible when I jacked up the front of the car and put it in gear to see the wheels spin.
I picked up a new CV half axle at Monument Auto Parts for $119 with a lifetime warranty. It was pretty easy to replace. Just take off the tire, take off the rotor, ABS line and then swing the knuckle off the shaft. I used a scewdriver to pry the joint off from where it connected to the motor but a slide hammer would have made it easier. Then took the new one and just slid it back in and put everything back on in reverse order. Also, you will need to make sure you have the correct socket to remove the axle nut (also pry up the crush groove or you'll damage the threads).
Old 07-13-2009, 04:55 PM   #7
FUSCION YO!
HaoleXB is on a distinguished road
Send a message via AIM to HaoleXB
Re: CV Joint Death
^^^ what he said. replaced mine due to torn boot, but i also ended up tearing the side tranny seal when reinstalling the new CV. i replaced the seal and musta torn it again, cus it still leaks like 2-3 drops a day . def need the slide hammer to get the axle outta the trans easily. its for sure not an easy job. expect 4-8 hrs depending on your mechanic skillz.
HaoleXB is online now   Reply With Quote
Old 07-13-2009, 05:11 PM   #8
Re: CV Joint Death
Wedge a prybar between the inner CV and trans case and hit the opposite side of the CV joint with a hammer. Always worked for me.
Old 07-13-2009, 05:31 PM   #9
859Toaster's Avatar
Re: CV Joint Death
I had mine replaced by Toyota for free YAY! Warranties!
Old 07-13-2009, 08:52 PM   #10
Lifex's Avatar
Re: CV Joint Death
im just gonna say this . . .
Rule Out The Obvious
Old 07-14-2009, 12:29 AM   #11
859Toaster's Avatar
Re: CV Joint Death
operator error? lol
Old 07-14-2009, 12:36 AM   #12
Lifex's Avatar
Re: CV Joint Death
more like co-pilot but, uh, its all better now and don't need to spend money anymore except things i want to spend money on
Old 07-14-2009, 09:32 AM   #13
859Toaster's Avatar
Re: CV Joint Death
Sellf pwn3d
Old 07-14-2009, 04:05 PM   #14
Re: CV Joint Death
What gives?
What was the fix for all the clunking?
Kazzak is offline   Reply With Quote
Old 07-14-2009, 05:15 PM   #15
859Toaster's Avatar
Re: CV Joint Death
Someone didn't know how to properly work a lug wrench. lol
Old 07-14-2009, 06:21 PM   #16
Lifex's Avatar
Re: CV Joint Death
hey! i hand tightened them and they lasted for a day and a half - regardless, its my fathers fault and i don't really blame him cause nothing serious happened
Time for Brake pads already?
Page generated in 0.23069 seconds with 13 queries
