10-10-2008, 05:58 PM
#21 | | Registered User
| Re: Bagged by the great Randode Man i would love to have the front strut kit. |
10-10-2008, 06:31 PM
#22 | | I <3 Mooneyes
| Re: Bagged by the great Randode SAweeeeet.....I'm loving the xB more and more fo shoooo. I need to have Randode bag my xB :-( |
10-10-2008, 10:25 PM
#23 | | The one and ONLY
| Re: Bagged by the great Randode looks great.
thats one thing I need to do is remove my top spring mounts and re bolt mine in. |
10-12-2008, 11:56 AM
#24 | | Often Imitated
| Re: Bagged by the great Randode Quote:
Originally Posted by gothbox looks great.
thats one thing I need to do is remove my top spring mounts and re bolt mine in. | like this?  |
10-12-2008, 09:18 PM
#25 | | Registered User
| Re: Bagged by the great Randode did the holes match up on top and bottom so where u just cut the bottom bracket off or did u just make a new bracket? Also would air swivel fitting be rubbing on part of the metal strut tower when the strut turns since it sits up about and a inch? |
10-12-2008, 10:52 PM
#26 | | The one and ONLY
Originally Posted by randode like this?  | I like the way that looks, but I was talking about the back, my brackets are sitting on the top spring cup. I need to cut it out and move my bracket up higher on the frame. |
10-12-2008, 11:21 PM
#27 | | www.ScionApocalypse.com
| Re: Bagged by the great Randode It wont help you any Goth. Your already pinching brake lines. all that would do is shorten your suspension travel. correct?
We put the new struts on my car today. It drops lower than my first set and rides like a wet dream. |
10-12-2008, 11:24 PM
#28 | | The one and ONLY
| Re: Bagged by the great Randode yeah, I am already sitting as low as I can in the back, but I figure what the hell right? ha ha
I told you the ride is great on them, I love the way they ride now.
I am waiting more info on what and how.  |
10-12-2008, 11:36 PM
#29 | | www.ScionApocalypse.com
Originally Posted by gothbox yeah, I am already sitting as low as I can in the back, but I figure what the hell right? ha ha
I am waiting more info on what and how.  | I hear that. my other ones were stiff as hell..Not the case anymore. Randode just needs to start making replacement plates asap to take car of the demand.
I wanted to wait until today to expose the modification but obviously Randy jumped the gun with his pic yesterday. |
10-12-2008, 11:38 PM
#30 | | The one and ONLY
| Re: Bagged by the great Randode mine were stiff, and would stick, I had to let just about all the air out and it would slam to to the ground. It is nice to be able to hit down ad the front actually go down.
ha ha yeah I guess he let the cat out of the bag, ha ha
so you hear that Randode? DO WORK! ha ha
10-12-2008, 11:44 PM
#31 | | Registered User
| Re: Bagged by the great Randode where was the threaded hole on top located at once u bolted them in my original set was in front by the tire now the new design strut hole is on the back side upwards the motor Im thinking the fab department got lazy and wasn't paying attention to where they crimped it at |
10-12-2008, 11:55 PM
#32 | | The one and ONLY
| Re: Bagged by the great Randode ok, this may be a dumb question, but could you just not flip the top mounting bracket over and or cut off where it attaches to the strut? to get the same result?
10-13-2008, 12:03 AM
#33 | | The one and ONLY
| Re: Bagged by the great Randode like in this pic. why cold you not just flip that over? |
10-13-2008, 12:33 AM
#34 | | Registered User
Originally Posted by gothbox like in this pic. why cold you not just flip that over? | It just won't work. It won't fit in the hole for the strut tower. |
10-13-2008, 12:34 AM
#35 | | The one and ONLY
| Re: Bagged by the great Randode but could you not just cut that stuff off? to make it flat? |
10-13-2008, 12:36 AM
#36 | | letzzzroll
| Re: Bagged by the great Randode dammm thats clean, but over bumb's you better watch your tank, so you dont puncture it
o: |
10-13-2008, 12:38 AM
#37 | | Often Imitated
Originally Posted by gothbox like in this pic. why cold you not just flip that over? | it wont fit the strut if you flip it over. Quote:
Originally Posted by txmadebox where was the threaded hole on top located at once u bolted them in my original set was in front by the tire now the new design strut hole is on the back side upwards the motor Im thinking the fab department got lazy and wasn't paying attention to where they crimped it at | u can twist the bag in any direction you want to aid in fitting clearance
#38 | | The one and ONLY
Originally Posted by randode it wont fit the strut if you flip it over. | ah, ok. thats what I needed to know. thanx Randode. |
10-13-2008, 12:39 AM
#39 | | www.ScionApocalypse.com
Originally Posted by gothbox but could you not just cut that stuff off? to make it flat? | That plate is the same plate but was cut,welded and grinded |
10-13-2008, 12:42 AM
#40 | | Registered User
| Re: Bagged by the great Randode I need to get new(er) pix up. I took out the 10mm axle spacers on Sunday and I'm now dragging my can. Running the Echo rear shocks and cut bump stops I'm now rubbing tire on the fender well. I'd really think about cutting it but the paint...oh the paint. I wouldn't want to have to go back to my painter to touch up my jambs if I cut it and rubbed tire on the jambs. |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | | All times are GMT -5. The time now is 08:31 PM. |
