Old 11-06-2009, 11:57 PM   #1
saved2live's Avatar
saved2live is on a distinguished road
Send a message via AIM to saved2live
What would cause this??
On my passenger side, the inside brake pad is wearing a lot quicker than the outside pad. I had my brother in law change my brake pads yesterday, and the inside pad was practically down to the metal whereas the outside pad had a little bit left. I know that brake calipers are expensive so I'm hoping nothing is wrong with mine and I end up having to replace it.
saved2live is offline   Reply With Quote
Old 11-07-2009, 02:48 AM   #2
Re: What would cause this??
Lubricate the slide pins (they have rubber boots around them). Use lithium based grease. And have the rotors machned.
Old 11-07-2009, 02:52 AM   #3
copper grease?......
Old 11-07-2009, 03:18 AM   #4
It's lithium from the factory. May be you'd want to clean the old grease out not to mix them together.
Old 11-07-2009, 02:46 PM   #5
saved2live's Avatar
What do you mean by having the rotors machined? Is it possible one side of my rotors is worn more than the other side?
Old 11-07-2009, 03:03 PM   #6
Possible, especially after the pads were not wearing properly. Resurfacing the rotors will straighten them out, help the new pads seat properly against the rotors, etc. Just the proper way to do it.
Old Today, 08:00 AM   #7
SoozBox's Avatar
SoozBox is on a distinguished road
Like PCH said, clean and lube the slide pins. Calipers have to "float" to work right. When one side hits the rotor before the other, the caliper needs to be able to slide to center itself so the force is equal on both sides. If the caliper won't slide well enough or at all, the first pad to touch will be doing too much of the work.
SoozBox is offline   Reply With Quote
Work Wheels Showoff
rims, what kind do you have?
Xb with 15" Rims
xxr 513 black red lip
15x13 -119 on an xb
Page generated in 0.16764 seconds with 13 queries
