Old 12-19-2008, 02:49 AM   #1
brodey1 is on a distinguished road
Sportmax (XXR) 501 rivet problems?
I've been doing research on the 501's, and I've ran across a few mentions of rivets falling out.
It doesn't seem to be an issue of function, only cosmetic.
Apparantly you can order new rivets from Sportmax to replace the missing ones.
Does anyone know anything about this?
I am close to ordering a set, I'm now questioning the quality.
Any help would be appreciated.
Blain
brodey1 is offline   Reply With Quote
Old 12-21-2008, 09:53 AM   #2
Resident Rhode Islander
Toup's Avatar
Re: Sportmax (XXR) 501 rivet problems?
rivets fallin off left and right
Maybe that thread will help you out...
Toup is online now   Reply With Quote
Old 12-22-2008, 12:55 AM   #3
Thanks Toup!! I guess I'll not be going with the those, sucks, I really like the way they look.
Old 12-22-2008, 01:23 AM   #4
LOW!!!
xBtony's Avatar
Um..I bought mine used with like what 5-7k on em.since then I've put um...maybe another 7 on em..Mine arnt even clost to lose...Lol...And if any of mine do fall off..Im just gunna rip all of em off...OfasxB did that to his 501's when he had em..Still looked cool, actually it looked cleaner..and it would make it WAY easier to clean...What was said in that thread was true..They are cheap rims..I wont doubt that...And one day I will have some sick, quality rims..Till then Im sticken' with my Sportmax.
Old 12-24-2008, 12:52 AM   #5
06 TCM xB-RS
gravebox's Avatar
there's a company that you can order rivet replacements that are metal to replace the plastic ones in the sportmax / XXR wheels.
i don't remember the name of website, but i know it's out there. gotta take out the plastic ones and then the new ones come with threading to go in nice and tight and stay in if i remember correctly.
do know that, sportmax / XXR wheels are a cheap buy to begin with so... i wouldn't be surprised if the rivets fell out. hell i'll be using 002's for my rally setup. functionality is pretty solid on those and for what i'm doing, i'm expecting the rivets to be missing.
Old 12-24-2008, 08:26 AM   #6
The Hater
TypeX's Avatar
TypeX is on a distinguished road
Send a message via AIM to TypeX
I've read that depending on where you purchased that if you contact the seller about the rivets theyw ill replace the wheel.
I got my 501's from Nlmotoring.com since they were the site that was referenced in replacing the ENTIRE WHEEL...for missing rivets.
TypeX is offline   Reply With Quote
Old 12-26-2008, 06:53 AM   #7
I've been going back and forth in my head between the 501's and the Drag DR-20's. Both seem to be pretty well thought of for the money. I now have the moolah and am ready to order, I think.
I was on Nlmotoring looking at the specifics and I saw where it says the required lug-nut is "tuner style". Do I really need to order new lug-nuts? Not a biggie, they're only like $25 on the same site, I just want to get it right the first time.
Also, really just opinions needed here...which one of these will look cooler, ie flush, deep, etc.
-15x7 +38 1.5"lip or 15x8 +15 3"lip?
These are going on stock rubber.
Thanks!
Old 12-26-2008, 06:58 AM   #8
The Hater
TypeX's Avatar
You can run them two ways
Higher offset in front with lower in rear for 'staggard'
Or. 15. All around
I opted for 15 all around
You can't use oem lugs u need a tuner "style" 25 bucks is decent unless u want flashy or colors and want to spend more
As for tires they will mount fine
Just search the forums fir guys running the same suspension as u ( if any)
And inquire about rubbing etc
Good luck
Old 12-26-2008, 07:03 PM   #9
06 TCM xB-RS
gravebox's Avatar
ET15 all around man, it'll look REAL nice. the back wont be flush, you'd need a set of 10mm spacers if i'm not mistaken but the front will be perfect.
don't let the 10mm bug you though, that's just 1 centimeter or just over a quater inch. at first glance it's not noticeable unless you REALLY eye ball the clearance.
you'll need the tuner lugs for any new rims. they do that for owner security reasons and i would highly suggest getting 2 sets of 2 different locking lugs, both with different locking key tools from one another to insure that you wont wake up one morning to find your xB on blocks...
Old 12-30-2008, 02:54 PM   #10
grizzly_choppers's Avatar
I don't remember having any problems with the rivets on my 002s (I'm pretty sure they are the same arrangement). The new leopard set had those removed, holes drilled, tapped and allen head bolts put in. They look damn slick. Ton of effort though (glad I didn't have to do it actually).
Good luck on your decision!
-Alex
grizzly_choppers is offline   Reply With Quote
Old 11-05-2009, 10:56 AM   #11
Crossin' Fingers
brownfaux is on a distinguished road
My rivets haven't fallen out, yet, but I am looking at other options. I've seen them completely yanked out (n2hotwheelz), ive seen spikes (gothbox), and I have seen the leopard wheels like the above post. I like the hex head bolt idea, as I'm looking to do a more flush look with the rivets, anyone have more info on how he did that? Or any other suggestions>?
brownfaux is offline   Reply With Quote
Old 11-05-2009, 10:59 AM   #12
JDM pawn shop
big_hungry's Avatar
big_hungry is on a distinguished road
Send a message via AIM to big_hungry Send a message via Yahoo to big_hungry
i had some 002's for about a year or so and the rivets never fell out on me.
big_hungry is offline   Reply With Quote
Old 11-05-2009, 04:02 PM   #13
LOW!!!
xBtony's Avatar
This thread makes me wanna rip mine out..haha!
Old 11-05-2009, 04:06 PM   #14
rushbuster70's Avatar
rushbuster70 is on a distinguished road
had mine for at least 5k.no probs.saw them the other day.have around 15k on them now and still look good
rushbuster70 is online now   Reply With Quote
Old 11-16-2009, 04:40 AM   #15
Team H.F.D.
PONGsXB's Avatar
PONGsXB is on a distinguished road
Send a message via AIM to PONGsXB
do it Tony rip them bishes off..and put spikes in them!
PONGsXB is offline   Reply With Quote
Old 11-16-2009, 08:04 PM   #16
LOW!!!
xBtony's Avatar
^Oh its already done
If anyone wants some spare rivits. i have like 80.
Old 11-17-2009, 03:55 AM   #17
Canadian Box
Beyond's Avatar
Beyond is on a distinguished road
Yeup. Do it! Took me 10 minutes flat for all 4 wheels.
IMO it' looks even better.
Beyond is offline   Reply With Quote
Work Wheels Showoff
rims, what kind do you have?
Xb with 15" Rims
xxr 513 black red lip
15x13 -119 on an xb
Page generated in 0.22218 seconds with 13 queries
