12-13-2006, 10:59 AM
#41 | | Nor*Cal's Most Hated
| Quote:
Originally Posted by suspended and on adjusting the toe issue, you CAN do it in the rear, but not like you would in the front..it is true thats its non "adjustable"...some alignment shops actually have small shims they can cut out at the specific angle that you need to get your toe straight (kinda like a camber shim, only going the other way), then they just take off the four bolts on the hub, stick it back there, and viola!  | Yes, that's the solution. I don't know of any shops in my area that has an alignment rack and a CNC/mill, that I can use all day to make the plates and check alignment. Nor the money.
But for those who want the closest thing, OTG camber shims are the way to go. |
12-13-2006, 11:28 AM
#42 | | Registered User
| they're not metal, its some kind of componsite material that shows where to cut it and gives the angle to cut it ;-), simple hand/air tools needed i believe, but there are two shops around here that will adjust toe on fixed rear hubs  it wouldn't hurt trying in your areas, just trying to help  |
12-13-2006, 11:30 AM
#43 | | Registered User
| or if you have a friend that works at a tires shop, you can always experiment with super thin washers to get the toe right on the alignment rack (just another suggestion) |
12-13-2006, 11:56 AM
#44 | |
| Quote:
Originally Posted by squirrel Yes, that's the solution. I don't know of any shops in my area that has an alignment rack and a CNC/mill, that I can use all day to make the plates and check alignment. Nor the money.
But for those who want the closest thing, OTG camber shims are the way to go. | i was thinking about seeing what auto inovations could do for me brad. i got new tires and lowered the rear again. i left my camera at bamm's so i don;t have any pics yet but next time i'm over there i will take a couple |
12-13-2006, 06:24 PM
#45 | | Nor*Cal's Most Hated
| Quote:
Originally Posted by suspended they're not metal, its some kind of componsite material that shows where to cut it and gives the angle to cut it ;-), simple hand/air tools needed i believe, but there are two shops around here that will adjust toe on fixed rear hubs  it wouldn't hurt trying in your areas, just trying to help  | Quote:
Originally Posted by suspended or if you have a friend that works at a tires shop, you can always experiment with super thin washers to get the toe right on the alignment rack (just another suggestion) | Living in the Democratic Republic of Kalifornia sucks sometimes. I'll have to make osme phone calls one day once things settle down.
I have the OTG camber shims that I was going to use in place of the DiParks, and I heard about the washer trick before also.
Better yet, I'll move out to FL and take yours!  |
12-14-2006, 11:18 AM
#46 | | Registered User
| you should move out here, i could always use a body gaurd....for your payment, washers!!!  |
