Old 06-25-2009, 09:04 PM   #1
Lifex's Avatar
Lifex will become famous soon enough
9.5" wide et15
Ok so i would just like to see if i am correct:
so i use to have wheels that where 7.5" wide (190.5mm) with a +45 offset making the the depth of the wheel essentially 140.25mm to the mount - which didn't fit cuz of wheel weights (facepalm) so add 10mm spacer = solved
I am switching to 9.5" wide (rears, 241.3mm) with an offset of +15 which makes them 135.65mm deep - so they should fit without spacers, correct? which it doesn't really matter because i am not taking those spacers off since it took me, like, 6-8 hours to install (thank you RUST)
just double checking, im testing fitting the wheels to make sure before the purchase - thanks in advance
Lifex is offline   Reply With Quote
Old 06-30-2009, 09:49 PM   #2
I'm outta here
toaster_pilot's Avatar
Re: 9.5" wide et15
so u running a 9.5" with a 10mm spacer? You know you gonna have about an inch of poke right? And u need the spacers
toaster_pilot is offline   Reply With Quote
Old 07-01-2009, 12:08 AM   #3
Lifex's Avatar
Re: 9.5" wide et15
yep i know
i was hoping if i take out the spacer that it would be fine but it looks like ill need to stiffen the suspension on roll fenders
Old 07-01-2009, 01:58 AM   #4
yellow_sub's Avatar
Re: 9.5" wide et15
you running that much poke you better roll haha
Old 07-01-2009, 02:00 AM   #5
regulatin' on foolz......
Re: 9.5" wide et15
Camber It!
Old 07-01-2009, 02:04 AM   #6
yellow_sub's Avatar
Re: 9.5" wide et15
camber and roll!!!
Old 07-01-2009, 06:00 AM   #7
Team H.F.D.
PONGsXB's Avatar
PONGsXB is on a distinguished road
Send a message via AIM to PONGsXB
Re: 9.5" wide et15
Amen I agree camber and roll ftmfw!!!
PONGsXB is offline   Reply With Quote
Old 07-01-2009, 06:43 PM   #8
Lifex's Avatar
Re: 9.5" wide et15
yea im gonna have to get camber but i need some suspension stiffining too - i also busted a spring today, i think damn camber has to be so expensive
Old 07-01-2009, 06:51 PM   #9
I'm outta here
Re: 9.5" wide et15
yeah, i poke around that much, little less, rolled but really need some -5's...
Old 07-02-2009, 04:30 AM   #10
HELA FASS DOOO
Re: 9.5" wide et15
poke, camber and roll. i hadto say it. then again i never make any sense sometimes.
Old 07-02-2009, 04:55 AM   #11
SE:Memphis
TheReaper's Avatar
TheReaper is on a distinguished road
Send a message via Yahoo to TheReaper
Re: 9.5" wide et15
yes definitely roll i learned the hard way and had a blowout do to the fender cutting into the sidewall
TheReaper is offline   Reply With Quote
Old 07-02-2009, 01:50 PM   #12
Lifex's Avatar
Re: 9.5" wide et15
so those fenders in the back are metal right? because im wearing the fender out but not the tire (? no idea) is the tutorial on fender rolling? i seen you can just put a pipe over the tire and roll forward . . . .bad idea?
Old 07-02-2009, 09:52 PM   #13
I'm outta here
Re: 9.5" wide et15
heat the paint!.....lol
and its not quite that easy
Last edited by toaster_pilot : 07-02-2009 at 09:52 PM. Reason: Automerged Doublepost
Old 07-02-2009, 10:40 PM   #14
FUSCION YO!
HaoleXB is on a distinguished road
Send a message via AIM to HaoleXB
Re: 9.5" wide et15
there is a rubberized coating over the metal. that is what is wearing away first before it gets to all metal. only way out is camber or air or spring stiffeners for the rear.
HaoleXB is offline   Reply With Quote
Old 07-03-2009, 01:44 AM   #15
Lifex's Avatar
Re: 9.5" wide et15
yea - im gonna try and pick up a set of koni sports for the rear and i did realize that there was sumthin that wasn't about the fender lip - thank you
Old 07-03-2009, 04:27 PM   #16
Big man, little box
Big_Bird's Avatar
Big_Bird is on a distinguished road
Re: 9.5" wide et15
Watching this one man.
Big_Bird is offline   Reply With Quote
Work Wheels Showoff
rims, what kind do you have?
Xb with 15" Rims
xxr 513 black red lip
Page generated in 0.21371 seconds with 13 queries
