Scion xB Wheels & TiresIn a culture where it's all about the kicks, your Scion xB shouldn't be left behind. Discuss with your fellow forum members what set of wheels and tires look best on your Scion xB, maybe even share where to find some great deals for Scion xB wheel and tire packages.
im running 195/60/15's in the rear with a 10mm spacer and -3 camber, slammed (coils spun alllllll the way down) on progress coilovers. I rub on bigger bumps with just me in the car. If i were to raise it up about a half inch to an inch i dont see it rubbing anymore.
I just want wider wheels not larger than stock diameter. I want 205's though and seems no one has done it. I guess 195's will be ok. I just hate the traction of 185's.
ive run the 195s on mine for over a yr of course no rub but if you r talking about running 205s on steelies i would not recommend it the ride is nicer mo grip and the bumps arent as harsh shortbus8 what kind of tires are those brand i mean. the sidewall looks better than mine
never mind 195/50 i have 195/60
You want wider TIRES not wheels... Well, wider wheels would be nice too, but 205/50 should work.
