Old 02-03-2009, 10:35 PM   #1
Speakers
what size is the dash,door,hatch speakers in the gen 1 xBs?
XB05 is offline   Reply With Quote
Old 02-03-2009, 10:49 PM   #2
DzSoLow
DzSoLow's Avatar
DzSoLow is on a distinguished road
Re: Speakers
speaker sizes of all speakers?
This should help.
DzSoLow is offline   Reply With Quote
Old 02-04-2009, 09:35 AM   #3
ChumleyEX's Avatar
ChumleyEX is on a distinguished road
Re: Speakers
Ah thats too much to read.. The dash takes 4" speakers, you can buy ring adapters for the front and rear and make them 6 1/2" ..
You just fold some tabs back on the 4"'s and they fit in the dash.
ChumleyEX is offline   Reply With Quote
Old 02-04-2009, 09:45 AM   #4
Re: Speakers
so the dash are 4" and the door,hatch are 6 1/2
Old 02-04-2009, 11:54 AM   #5
ChumleyEX's Avatar
Re: Speakers
For the 6 1/2s you will need spacers. You might be able to buy them at a best buy or something. They are fairly normal.
Scion/Mini Cooper Speaker Brackets 5-1/4" or 6-1/2" speaker adapter plates 2002-up Mini Cooper/2004-up Scion xB at Crutchfield.com
Also, due to the size of the speaker in the rear I had to dremel out part of the interior plastics. I only had to do it on one side. You may not have to do that.
And on the 4's you just bend/cut/snap 2 of the screw holes off/away.
Old 02-04-2009, 12:21 PM   #6
Re: Speakers
lol so are all the stock speakers in the first gen xBs 4" and u can get adapters to make them 6 1/2 " or are they 6 1/2 "
Old 02-04-2009, 12:50 PM   #7
ChumleyEX's Avatar
Re: Speakers
The dash ones are a special kind but the 4 thing is really easy.. They just fit right in with the tabs gone. The front speakers are 6.5 but they have a mounting bracket thing build into them. So when you drill them out (you have to drill out rivits to get them out) you will need a mounting bracket for them (as I linked) The rear speakers are 5 1/4 but 6.5s are better and normally the same price, so with the same bracket you can upgrade to a bigger louder speaker.
Old 02-04-2009, 03:41 PM   #8
Crabs is on a distinguished road
Re: Speakers
front stockies are 2 inch tweaters. but bending the two side pieces of a 4' and it will fit perfect using the existing wholes on the side.
The front doors. Best bet is 6.25's or 6.5's. All you gotta do is take a piece of 3/4 mdf and trace the templet off of the existing speaker mount that you pull out (gots to drill the existing 3 rivets and pop them real easy.
6.25's fit without the new mount ring but the magnet will not fit when the window is down so make sure you have clearance regardless of what you do.
Back is 5.25's stock but 6.25's fit and there is plenty of room to make the whole bigger to fit 6x9s or other similar speakers.
Crabs is offline   Reply With Quote
Old 02-04-2009, 03:44 PM   #9
Re: Speakers
hell yeah i appreciate it thanks
Old 05-18-2009, 09:08 PM   #10
willfong is on a distinguished road
Re: Speakers
Yes, I have older MB Quart 6.5" speakers for the rear locations of my 2005 Xb but my magnet and speaker basket wont fit into the stock hole. I even purchase the Crutchfield Sosche Speaker Adaptor Braket Plates for the rear and these wont fit my MB Quart speakers. The only way I can see fitting these MB Quarts into them would be cutting the sheet metal and making the whole larger then use sheet metal screws to mount a home made MDF mounting bracket.
Anyone have any thoughts as to what I should use to cut a nice larger circle around the existing mounting hole in the sheet metal?
Anyone else have this issue with trying to mount 6.5" speakers in the rear positions?
Thanks in advance!
willfong is offline   Reply With Quote
Old 05-18-2009, 09:23 PM   #11
viola000's Avatar
viola000 is on a distinguished road
Re: Speakers
I got my speaker adapters from Elemental Designs. If you look at them, they're pretty easy to make yourself.
viola000 is offline   Reply With Quote
Old 05-18-2009, 10:31 PM   #12
Re: Speakers
The only problem is if I used my older MB Quart speakers and made speaker adapter brackets out of MDF like the Elemental Designs I believe I still would need to cut the rear holes in the sheet metal to make them larger in order to fit the magnet and basket into it. Anyone ever had to do this?
I rather leave the hole stock and not cut the sheet metal but then I guess that would mean I would have to stick with stock 5.25" sized speakers?
Old 05-18-2009, 10:43 PM   #13
The Tattoo Guru
TattooAl's Avatar
Re: Speakers
yeah dude that just sounds like a ton of work for a slightly bigger speaker....
Old 05-21-2009, 02:57 PM   #14
ahughejazz24's Avatar
ahughejazz24 is on a distinguished road
Re: Speakers
I got kenwood speakers for the front doors and rear hatch area from
Find Car Audio/Video Gear that Fits Your Vehicle at Crutchfield!
The cool thing about using crutchfield is that they include the speaker brackets for free and the wire adapters so that you won't have to cut off the stock speaker plugs . Also, you can upgrade to 6.5" speakers up front with no problem at all.
ahughejazz24 is offline   Reply With Quote
Old 05-23-2009, 02:13 PM   #15
06 TCM xB-RS
gravebox's Avatar
Re: Speakers
i was aware that we had 3" dash *actual driver ssize*, 6.5 front door and 5.25 rear... and i'm pretty sure i measured this my self some time ago.
Old 05-29-2009, 03:10 AM   #16
Re: Speakers
I finally got some 4" Visonik Speakers for the dash cuz my box didn't come with any , but now I got 'em, and HOLY CRAP did they make a difference! Before, I had to keep the subs volume down cuz the music would sound choppy. I guess the bass canceled out some of the air waves or something, but now, with my new 2-way speakers in the front, I can blast the subs away without compromising the quality of my music!!!
Old 05-29-2009, 03:25 AM   #17
gamertag: Kurib0h
Kuriboh4's Avatar
Kuriboh4 is on a distinguished road
Send a message via AIM to Kuriboh4 Send a message via MSN to Kuriboh4
Re: Speakers
hey, i got 4 small 2 inch bose speakers that i wanna hook up to my car...
can anyone give me some ideas to start, cuz i dont.
thanks
Kuriboh4 is offline   Reply With Quote
Old 05-29-2009, 04:26 AM   #18
06 TCM xB-RS
gravebox's Avatar
Re: Speakers
it's due to improper crossovering on the stock setup. heavy bass will cause highs to become choppy those why it's better to have an aftermarket head unit that allows for lowpass and highpass croossover setups between the signal to the full range and to the subwoofer(s). bass IS sound waves, no matter what it does, it's all the same. thing about it is, anything below the 80-90hz zone is all omni directional which means no matter where it's facing, it's going to sound the same regardless... where as anything higher in frequency will start to depend on direction of fire or direction of fire towards deflection *bouncing from the winshield to you for example*. this is where you ennter the world of phasing characteristics and you start getting into wave form and alignment modeling in the developement field... but i'm not going that far.
it seems odd that you didn't have dash speakers in the first place... unless you bought your xB used.
thanks
did you mean 12 inch? or actually meant 2 inch?
if 2 inch... i hope they are high end based *tweeter based*, if not, they'll probably be useless.
also know, BOSE is NOT that great of an audio company. there isn't anything special about the things they do nor the drivers *speakers them selve's* they use. some are made by Eminence and others by P. Audio, both being Live Audio companies. Eminence has a few models that are "ok" and P. Audio has a good selection of rather nice products but they're not "the world's leading audio developement company". to name a few of the "best", it would have to be JBL, LabGrumpen, Crown International, Harman International, Dobly Digital and so on... which more than half of the list is owned by Harman International.
Old 05-29-2009, 04:50 AM   #19
Re: Speakers
Yeah, I got my xB used , but it used to be owned by the SAKURA .
As far as Bose goes, IDK. For home speakers, I would think that they're okay, for cars, I don't think they're all that great. I've had a couple of friends who've had bose components in their cars, and after a while, they sound and work like crap. I personally wouldn't buy them cuz there's more cost friendly, and performance friendly, components out there ^^^ JBL, Kicker, etc. etc., but that's just me.
However, if you already have them, then I guess you can use them for the dash speakers and maybe custom mount them on your A-pillars or rear doors for those riding in the back seats. Or if you have a sub box in the rear, maybe you can custom mount them on the box so the rear passengers can also hear he music and not just the bass.
Old 05-29-2009, 07:39 PM   #20
06 TCM xB-RS
gravebox's Avatar
Re: Speakers
in my honest opinion, i've never heard anything so crisp, clean and clear sounding over what the JBL 660GTI's produce...
you might spend 800-1000 for s single component system set of two mid drivers and two high drivers... but holy crap... so clean...
Stereo System Showoff
Radio Reception..
12" sub
Amp/sub adapter plug
Door lock / alarm audible
How secure is your box?
Stock stereo trick
my custom box box
Page generated in 0.25238 seconds with 13 queries
