Old 10-17-2006, 10:46 AM   #1
jimxb is on a distinguished road
Question Help! Kinetiks battery size for an xB
Thinking of getting a Kinitek battery to replace my OEM battery. I don't want a Optima. My OEM battery size is 9"L x 7" W x 7.5 H not including post. Did anybody have problems putting in a Kinetik HC 1800 which is 10"L x 6.5"W x 8.2" H (8.8" with post).
Also, is there enough slack in the battery cables to fit on correctly and did you need to get taller battery J rods to hold it down etc.
Reason, I am asking because it is a special order item from all the audio /electronic dealers in my area and can't be returned. None of the auto parts companies carry this brand to sample the fit.
Thanks for your help
jimxb is offline
Old 10-17-2006, 11:09 AM   #2
RS4 #303
sdsnybny's Avatar
Exclamation high
welcome to the club try e-mail to kinetics seen them at hin pretty big display the would know which battery would fit and mods to help if not in stock tray.
sdsnybny is offline
Old 10-17-2006, 11:23 AM   #3
Kinetiks company does not know what will fit your car and it seems that this product is ony sold thru audio /electronics stores. If it was sold at a auto parts store I would be able to test fit it, but the other stores don't allow this and some don't have it in stock , since they can get next day delivery..
Thanks, I still need input???
jimxb is offline
Old 10-17-2006, 11:43 PM   #4
RS4 #303
sdsnybny's Avatar
Wink still no results
go out and undo the battery bolts 2 bolts and the tie down also 2 bolts and check whats under it. my 88 toyo truck had a removable plastic tray that set into two notches. you could always get longer j bolts and matching nuts. with battery out you will get better idea if kinetics will fit and what could be done to accomidate larger size. if no one has done this allready thats your best bet
sdsnybny is offline
Old 10-18-2006, 07:51 AM   #5
Thanks, I going to see if I have the extra 1" lenght in width in battery size in my xB. I called Pep Boys auto repair, If I need new longer battery cables there about $12 ea. and $15 ea. to install
jimxb is offline
factory tire size? backseatchris Scion xB Wheels & Tires 14 11-15-2009 02:29 AM
What size monitor? CCSEBlackWidowxB Scion xB Audio, Video, & Security 9 04-12-2006 09:19 PM
Need seat bolt size Clown Master General Scion xB Discussion 14 03-26-2006 07:13 PM
Need Help With Battery azynboi03 Scion xB Audio, Video, & Security 6 03-23-2006 10:56 AM
Dead Battery and Clicking Polar Express Scion xB Engine, Tech, & Performance 13 01-31-2006 02:08 AM
Stereo System Showoff
Radio Reception..
12" sub
Door lock / alarm audible
Amp/sub adapter plug
my custom box box
How secure is your box?
Stock stereo trick
Page generated in 0.13634 seconds with 14 queries
