Originally Posted by superfreestyle this will help...
i have the 9855 with the biolite display...
refer to page 29 in your alpine owner's manual, in the top right corner it has a bold heading that says "Audio Setting", look under the first sub-title called "Subwoofer On and Off", that section tells you how to get to the menu and the last line of that section tells you how to adjust the level. |
Thanks for the post. The setting is actually found by depressing the volume knob until the subwoofer menu appears, then turning the volume knob until the desired level is reached. (0-15) The instructions in the manual only lead to the on/off setting for the subwoofer. The manual had the wrong information printed. There were other things that the manual says the head unit does but it does not. Alpine figured it was cheaper and easier to tell people on the phone than to reprint the manual.
