Old 04-24-2009, 01:30 AM   #1
ithewitchfinder's Avatar
ithewitchfinder is on a distinguished road
Head Unit Installation...
I have this head unit Dual XDMR7710
and I was looking at these mounts 2004 2005 2006 2007 Scion xB Radio Install Dash Kit and Radio Dash Mount SCION, would these to items be all that I would need to install this deck into the space where the factory radio is located? If so, which mount would be better? In addition, would it be easier to install this deck in that smaller glove box area ilocated under the "Fasten Seatbelt" alert?
FYI: I am planning on adding a Bazooka BT1224DVC 12" sub powered by a Kicker amp to this set up in the near future, which is why I am entertaining the idea of switchin out the head unit.....
ithewitchfinder is offline
Old 04-24-2009, 01:55 AM   #2
xb_release_2's Avatar
xb_release_2 is on a distinguished road
Re: Head Unit Installation...
any single din dash kit for the scion xb will work. i prefer metra brand! good luck!!!!!!!
and if you dont wanna go through the hassle of getting all that all you need is a LOC (Line Output Converter) and you can run factory head unit to a amp. you will need to tap into your radio harness for your ignition wire.
Last edited by xb_release_2 : 04-24-2009 at 01:55 AM. Reason: Automerged Doublepost
xb_release_2 is offline
Old 04-24-2009, 01:57 AM   #3
infeliciter's Avatar
Location: climbing out a grave, 'Cause I'm back from the dead.
i dont think that this HU would be able to work/fit well in the "oven" based off of its flip face. seems like it would be in the way for of the shifter (unless you have an auto but then it would be difficult in park)
infeliciter is online now
Stereo System Showoff
Radio Reception..
12" sub
Amp/sub adapter plug
Door lock / alarm audible
my custom box box
How secure is your box?
Stock stereo trick
Page generated in 0.14237 seconds with 13 queries
