09-29-2009, 09:26 AM
#1 | | ohayo gozaimasu
| yellowest fog lights non-oem/HID ... Hi. I want to know what are the yellowest fog lights one can get that are not in the oem housing AND are non HID. I went to walmart and saw the blazer ones for like 23 dollars but are there any other options you guys might know about? amazon has Hella optilux 1450's for like 30 something bucks... |
09-30-2009, 07:40 PM
#2 | | ohayo gozaimasu
| Re: yellowest fog lights non-oem/HID ... |
09-30-2009, 08:04 PM
#3 | |
| Re: yellowest fog lights non-oem/HID ... They sell OEM style yellow tinted fog light housings on ebay that are pretty darn yellow. |
09-30-2009, 08:07 PM
#4 | |
| Re: yellowest fog lights non-oem/HID ... i donno.... i finally got the yellow bulbs today after like 9 days of waiting by the mail box for my front marker/blinker lights on my gen 2 but i wont know how yellow they are until tonight.... |
09-30-2009, 11:59 PM
#5 | |
| Re: yellowest fog lights non-oem/HID ... Piaa makes bright ass fogs, but they aint cheap from what i remember |
10-01-2009, 12:13 AM
| Re: yellowest fog lights non-oem/HID ... I got the yellow, wally world ones. The pretty yellow, good for 2 bucks. The bulbs aren't yellow though, but they look yellow cause the gold reflector on the inside. They fit great in place of the pop out thing on the lower grill. Hope i never need a tow. . . |
10-01-2009, 12:09 PM
#7 | | ohayo gozaimasu
| Re: yellowest fog lights non-oem/HID ... you guys are great! thanks im going to look into piaa and i couldnt really find any wally world fog lights??? just an amusement park lol
i think i'm going to go with the hella optilux 1450 and then buy some "H3 NOKYA HYPER YELLOW BULBS 70W 2500K STAGE 1" from ebay...
10-01-2009, 12:57 PM
#8 | | ClubxB's OG Member
10-01-2009, 01:08 PM
#9 | | 06.5 TCM
10-01-2009, 02:19 PM
#10 | | ohayo gozaimasu
| Re: yellowest fog lights non-oem/HID ... that looks hella sickkkkkk |
10-01-2009, 03:42 PM
#11 | |
| Re: yellowest fog lights non-oem/HID ... Alright, here is yellow headlight bulbs: (note, these are NOT HID)
Here is McCulloch 3000K HIDS: (these are REAL HIDS, ballast, igniters and all)
These are Amber Fogs: (OEM Lens, painted Amber.. There is a DIY in the DIY section)
What you are referring too in your OP are not HID Fogs. They are Halogen Fogs. Unfortunately the term HID is properly miss used amongst brand packaging, and has effectively become miss used amongst consumers...
An HID lighting system is a gas filled light bulb, a ballast, a igniter and relay, as well as a power supply. If you are just replacing a bulb, and not adding extra power (or essentially wiring) it is not an HID. Just a Simulated HID color. |
10-01-2009, 04:59 PM
#12 | | ohayo gozaimasu
| Re: yellowest fog lights non-oem/HID ... well i'm planning on getting hid fogs in the future but wanted something really yellow without going hid for now. i'm HELLA broke!!! |
10-01-2009, 10:30 PM
#13 | | gamertag: Kurib0h
| Re: yellowest fog lights non-oem/HID ... how difficult would it be to install the non-oem fog lights that go on the lower grill?
would you have to drill? or remove the bumper? and also the switch as well, how do we go about on that? |
10-02-2009, 12:14 AM
#14 | | I <3 my bB
| Re: yellowest fog lights non-oem/HID ... personally just spend the 60-80 bucks and get some 3000k hids...thats what i did and i usually run only my fogs at night... |
10-02-2009, 07:46 AM
#15 | | Registered User
| Re: yellowest fog lights non-oem/HID ... lamin-x
since I cant post links for another 4 posts - google the above.
make any light any color you want. I suggest using lamin-x and a good yellow bulb (ebay ones worked just fine for me) and you should be golden (hehe) |
10-02-2009, 08:57 AM
#16 | | Supra dude here...
| Re: yellowest fog lights non-oem/HID ... I've had painted housings, yellow bulbs and finally Lexus/Acura inserts on my supras, and the yellowest of all, is the Lexus/Acura inserts. I have plain yellow bulbs from eBay on my OEM xB's fogs, but I'm thinking of converting them to signals, and having fogs in the headlights... |
10-03-2009, 08:37 AM
#17 | | bB Squad
| Re: yellowest fog lights non-oem/HID ... stay away from the ebay bulbs... wattage is too high and will eventually burn your harnesses....
get your bulbs from H4 Solaris Yellow... they have the bulb you need and at the right wattage |
10-03-2009, 11:17 AM
#18 | | Registered User
| Re: yellowest fog lights non-oem/HID ... Quote:
Originally Posted by Kuriboh4 how difficult would it be to install the non-oem fog lights that go on the lower grill?
would you have to drill? or remove the bumper? and also the switch as well, how do we go about on that? | I took the mesh gill inserts out and drilled a hole behind them. I have a bolt going through the back of the fog light housing and through the bumper. You can reach underneath to put on a nut on the inside of the bumper.
If you keep the mesh inserts, the mod is completely reversible.
As for the wiring, if you done any before, its easy. Go google how a relay works. You can get a headlight one from any parts store or junk yard, get the cheapest one. I tapped my dimmer switch for the 12v signal, so my fogs go on with my sidemarkers/headlights. I also have separate switch to turn the fogs by themselves.
I would write a DIY, but there are so many on this subject.
Good Luck! |
10-03-2009, 02:57 PM
#19 | | gamertag: Kurib0h
Originally Posted by Lt4mula I took the mesh gill inserts out and drilled a hole behind them. I have a bolt going through the back of the fog light housing and through the bumper. You can reach underneath to put on a nut on the inside of the bumper.
Good Luck! | so by mesh inserts, u mean the ones the pop out blocking the tow hook? and you drilled the fogs to those? wouldnt you be afraid of them falling off??
i havent done wiring before so i wouldnt know...so isnt it possible to hook it to the battery?
thanks! |
10-03-2009, 10:26 PM
#20 | | ohayo gozaimasu
| Re: yellowest fog lights non-oem/HID ... i just found these mesh grill covers the other day. there are two honeycomb like covers on the lower part of the grill, just pull with your finger. i popped one out and put it back in...haiyooo
i think i WILL go hid. 12000 and 3000 fog lights?
