Old 06-01-2007, 07:57 PM   #21
RS 4.0 #1130
blimey's Avatar
blimey is on a distinguished road
Re: door lock led dyi guide
Originally Posted by tetro View Post
HELPPPPPP
HOW DO YOU TAP THE WIRE IN????
i recieved my lights today but i can't figure out how to tap the wire in.....
I used a splice connector like these.The only difference is the one I used had a spade that plug into it.
blimey is offline
Old 06-01-2007, 11:55 PM   #22
tetro's Avatar
tetro is on a distinguished road
Send a message via AIM to tetro
where do you get thoose at??
tetro is offline
Old 06-02-2007, 01:50 AM   #23
BurxBox's Avatar
BurxBox is on a distinguished road
These are what I use. They are called a t-tap. You can get them at Napa
There is the tap that is blue for 12-16 ga. wire then there are the male pieces that fit into them.
I use these so if I need to diconnect to move I can and dont have to cut wires.
Just a thought.
BurxBox is offline
Old 06-02-2007, 01:53 AM   #24
BurxBox's Avatar
Sorry forgot the pic
BurxBox is offline
Old 06-02-2007, 12:32 PM   #25
tetro's Avatar
thanks i might be asking about wiring later.
tetro is offline
Old 06-02-2007, 07:16 PM   #26
Spiderbox is on a distinguished road
anyone with an 06 auto xb have the bottom shifter bezel?
i know someone said they have to trim to make it fit but i examined it carefully and the superfa bezel is identical to the stock bezel, the only difference is the led and resistor ring which i dont think i can trim off.
Spiderbox is offline
Old 06-03-2007, 02:09 PM   #27
yellow_sub's Avatar
dude that cat5 wire idea is awesome thanks taz!
yellow_sub is offline
Old 06-03-2007, 02:29 PM   #28
Here to help.
Old 06-19-2007, 09:57 PM   #29
CoToaster_Pilot's Avatar
CoToaster_Pilot is on a distinguished road
Send a message via AIM to CoToaster_Pilot Send a message via Yahoo to CoToaster_Pilot
do the lights stay on all the time? im getting some and i want to learn up on them. i dont want to wire them to a switch or anything.
CoToaster_Pilot is offline
Old 06-20-2007, 11:58 AM   #30
tetro's Avatar
Everytime you turn your ignition on they turn on.
Hey does anyone know what wire your suppose to crip the wire to on the front doors i got the back buit i can't figure out the front. I have a RS 1.0. Help??
tetro is offline
Old 06-20-2007, 02:28 PM   #31
whoo cool thanks!!
Side marker Re-wire
Cold Cathode Wiring Diagrams
Page generated in 0.23043 seconds with 13 queries
