Old 11-28-2007, 05:06 AM   #1
dasaint80 is on a distinguished road
Send a message via AIM to dasaint80
Disclaimer: I'm NOT responsible for any damage done to your vehicle.
Click on pictures for larger Views.
Let’s get started
IF you never solder or are not comfortable with soldering;
1. Please read some tutorials.
Soldering Tutorials 1
Soldering Tutorials 2
2. Practice. I like to practice with some old/broke circuit boards, there’s no risk in braking what’s already broken!!
3. Patience. Please Take your time and look at what you’re going to be removing/modding.
Tools:
1. Solder Station. Any Solder Station will do. I recommend weller solder stations. Remember most of the components are very small so get a station that is able have different Tips.
2. Solder Wick/Braid. Get here.
3. Reverse Action Tweezers These are great for soldering Small components. Get here.
4. Solder.
Parts:
Most of the LEDs we’re going to be changing are “PLCC-2”.
I buy mine from ebay, Great Price and great turnouts!! Here’s who I use
HKJE LED Lamp Center.
Let’s get started!!
Follow these steps and Get associated with the gauges as we go along.
Here’s what it looks like all pretty and new!
Remove the Gauge Cover. Remove 4 Screws.
Remove the Gauge Connectors.
Remove 8 Screws and back cover.
Here’s what you’re looking at when the cover is removed.
Press Slightly on the Black Tabs to Remove the Front Cover. There’s 4 Tabs, 2 at the bottom and 2 at the top.
Here’s what we’re looking at now. Remember where the needles sit. Remove the Needles and Gauge face plate.
Let’s Remove the Circuit Board from the housing. The board should come out easily except for the section where the LCDs are connected. I used a small Flat head Screw drive to pry the circuit board out. BE PATIENT AND TAKE YOUR TIME!!!!!
Here’s the Circuit Board in all its Glory. Cue the Mystical Music. ”AHahahahaAHahaHah”.
And here’s what everything is.
Apply the solder iron tip each side the LED one at a time. If the LED doesn’t Budge use some solder wick.
Once LED is removed, apply Solder to the silver pad, if you put to much remove it with the solder wick and try again.
NOTE:
The LED will have a small notch at one corner. That tell you that Cathode leg of the LED. Face the Notch towards the Cathode Drawing on the circuit board.
Place the new LED in between the silver pad while holding the LED with the Reverse action Tweezers, hit each Leg of the LED with the solder iron to solder the LED in place.
Repeat for all other LEDs you want to replace.
Here’s the Finished product.
Any comments please PMME.
dasaint80 is offline
Old 11-28-2007, 05:08 AM   #2
HELA FASS DOOO
Re: DIY: LED swap Tutorial (Somewhat friendly 56k!!)
that looks nice fer sure! keep up the good work.
ketchup_xb is offline
Old 11-28-2007, 05:16 AM   #3
Thanks, I'm here to share. if you guys need some more DIY just tell me I'll see what I can do.
I GOT SOME BIG DIY COMING UP!!!!
Old 11-28-2007, 05:17 AM   #4
HELA FASS DOOO
i have the first gen though. lol
Old 11-28-2007, 08:13 AM   #5
Looks good.
Old 11-28-2007, 08:16 AM   #6
bcherry's Avatar
bcherry is on a distinguished road
where are you located?
bcherry is offline
Old 11-28-2007, 10:08 AM   #7
bcherry: I'm in philly,PA. we can work something out with shipments.
ketchup_xb: Well the walk throught is still good for 1st gen just less LEDs!!!
Old 11-28-2007, 10:22 AM   #8
VIP Member
Creeping on a come up
EZBAKED's Avatar
EZBAKED is on a distinguished road
NICE. LEDs are love.
EZBAKED is offline
Old 11-28-2007, 10:44 AM   #9
#1517 RS1
teamneon's Avatar
teamneon is on a distinguished road
halo headlights? i know its been done...just havent seen a tutorial
i want ORANGE! lol
teamneon is offline
Old 11-28-2007, 03:01 PM   #10
demonics12's Avatar
demonics12 is on a distinguished road
Send a message via AIM to demonics12
i tried pming, but you dont allow it?
id like to discuss what you can do for my rs4
demonics12 is offline
Old 11-29-2007, 12:39 AM   #11
HMmm......let me check my settings.
It showed be working now@!!
Side marker Re-wire
Cold Cathode Wiring Diagrams
door lock led dyi guide
Page generated in 0.21293 seconds with 13 queries
