Old 05-20-2008, 03:22 PM   #1
GregS's Avatar
DIY 2nd Gen Steerng Wheel Control lighting change
Just a quick how-to for those who wish o change out the amber light in the steering wheel controls to match the other lighting that they have changed in the gauge cluster.
DISCLAIMER: If you blow your airbag it's not my fault. Also don't attempt this if you are not comfortable using a soldering iron and doing small circuit board work.
Ok, now that that is out of the way here we go.
GregS is offline
Old 05-20-2008, 03:28 PM   #2
Re: DIY 2nd Gen Steerng Wheel Control lighting change
Awsome step-by-step! I can tell you are a pro
How about some extra info on the LED. What P.N.#, etc.
PCH is offline
Old 05-20-2008, 04:00 PM   #3
Mother Lover...
Good job!!!
Padanky is offline
Old 05-20-2008, 04:21 PM   #4
GregS's Avatar
Sorry about that I had to leave before I got the comments up. Forgot today was a minimum day at school for my older daughter and I had to go and pick her up.
Comments are coming.
First and foremost disconnect the negative terminal from your battery. probably don't have to as you won't actually be disconnecting the airbag but no need to risk it.
Obviously this is the steering wheel.
Left side screw. Looks to be a 27-30 Torx head.
Right side screw, same as left.
If you don't happen to have a Torx driver, or in my case don't have one long enough to reach the screw turns out a 4mm allan head works just as well.
This shows how far in it is.
Once you loosen the screw it will stay in so don't worry about losing it.
Right side screw loosening.
At this point the airbag/horn assembly will just come right off.
Lay it down hanging from the wires.
See the single line on the left of the assemble. That is the horn line which you will need to unplug as it and the radio controls are in the same harness.
Just use a small flat head screwdriver to release the clip holding it on.
Do the same to the middle harness on the column.
Now the middle plug is out of the way.
There is one screw just at the left edge of the open area. It hold the controls in place.
Now with that screw removed you will be able to pull the controls out. It is a little tight so just pull and wiggle it a little bit.
Once loose away it goes to a more convient work space.
Here is the control assemble on my work bench, ignore the mess I've been doing a lot of fiberglassing lately.
Backside of the assembly. You can see the two small phillips screws that ned to be removed.
Screws removed.
There is one tab on the botton right that need to be openned up with a small flat head screwdriver.
And another on the top left.
Now you will be able to open the whole thing up. Here is the front, circuit board and back cover spread out.
Note the tiny ass size of the LED on the circuit board.
Here it is in comparison to the PLCC-2 LEDs used inthe gauge cluster. The correct LED size is a 1206 I have been told.
Just a shot so those who don't understand what a surface mount LED is can see. There are no solder points on the back of the circuit board, everything is soldered from the front side.
Here I am de-soldering the stock LED. All you really need to do it get a low wattage solding iron completely hot, hold it against tone end of the LED and push slightly. Once the solder has melted the LED will push up and out of the way. Repeat to the other half of the LED.
In my case since I had a few PLCC-2 LED left over from doing the gauge cluster I just used one of the for the radio controls. It's a tight fit but it works well.
Assembly is the reverse of disassembly.
Here is a shot witht he lights off.
And now with the lights on it is blue to match the rest of the dash and AC lights.
Coments and questions?
Well crap I managed to screw up and put the comments in a quote. Oh well, at least it's up.
GregS is offline
Old 05-20-2008, 08:35 PM   #5
Aaron93's Avatar
Aaron93 is on a distinguished road
Thanks Greg!!! If I am able to do this I will owe all the credit to you!! I have never worked on a board but I have an electronics repair shop that will be doing the work for me I just have to disassemble it for them. Once again Thanks!!
Aaron93 is offline
Old 05-20-2008, 09:13 PM   #6
GregS's Avatar
You should be fine, if any one in the repair shop can't do it then they shouldn't be there as it is very simple work.
GregS is offline
Old 05-20-2008, 09:50 PM   #7
Aaron93's Avatar
Thanks! I have ordered 25 PLCC-2 lights. Can I use the same type LED for the AC, Steering Wheel, Dash, and Door? I know you said the door was a tight fit but it did work. What about the rest?
Aaron93 is offline
Old 05-20-2008, 10:39 PM   #8
GregS's Avatar
It'll work for the dash and the steering wheel, not the door or the AC. The AC uses twist in removeable lights and I just de-soldered one of them from it's housing and used it in the door. You can use then in the radio if you want, as they are the same as the steering wheel. You might have enough as I ordered 20 and still have 4 left over after doing the dash and steering wheel. I know there were a lot in the radio but I'm not sure how many. for the AC you need neo wedge bulbs.
Here's the link for the thread;
http://www.clubxb.com/forums/f19/424...-no-soldering/
GregS is offline
Old 05-22-2008, 10:11 AM   #9
Aaron93's Avatar
Thanks!!!!!
Aaron93 is offline
Old 05-22-2008, 10:28 AM   #10
Revrent is on a distinguished road
Send a message via Yahoo to Revrent Send a message via Skype™ to Revrent
Thanks, I was a little nervous about doing this but wont be now.
God bless
John
Revrent is offline
Old 07-09-2008, 12:44 AM   #11
therhino is on a distinguished road
I owe it to you GregS....Popped that single LED out and soldered in a blue LED
One word of caution: IT IS SUPER BRIGHT!!! and does not dim but it looks clean
All thanks go to you Greg.
therhino is offline
Side marker Re-wire
Cold Cathode Wiring Diagrams
door lock led dyi guide
Page generated in 0.27449 seconds with 13 queries
