Go Back   Scion xB Forum > Scion xB DIY Articles > DIY Articles > Scion xB General
Old 01-11-2006, 10:35 PM   #1
DIY: ECU Reset w/o disconnecting the negative terminal
Difficulty: (1-5): 1
Time Frame: 1 min
Here is how to reset your ECU without disconnecting the negative terminal on your battery.
This will work for those who have installed new parts, have gotten a CEL (Check Engine Light), and do not want to risk losing their trip meter settings, radio presents, etc.......
- Make sure the car is off and the key is not in the ignition.
- Open the hood and locate the "Engine Room Relay Box." This is the fuse/relay box in the engine bay. On the xA/xB, it is the black top box to the right (Driver's side) of the engine bay next to the strut tower.
- Take the black cover off and flip it over to read the embossed diagram. You want to look for the "EFI" fuse (NOT RELAY). On the xA/xB, the EFI fuse is 15 Amps.
On the xB, the EFI fuse is #12:
- Using the fuse-puller (white piece of plastic in the box), pull the EFI fuse out and set it aside for at least 30 seconds.
- Put the fuse back in the EFI fuse socket. Make sure it is properly seated, and is uniform with the other fuses.
- Replace the black cover.
- Start up the car, and you shouldn't pull another CEL (Check Engine Light).
- If you are successful in not pulling a CEL, I recommend you let the car for 5-10 minutes for good measure.
squirrel is offline
Old 03-26-2006, 06:53 PM   #2
short bus's Avatar
thanks
thank you
Time Frame: 1 min
short bus is offline
« - | Paint codes »
Paint codes
How To: Ship wheels and tires.
Zenesis E502 Install DIY xB Gen 1
DIY: How to make JDM look from a germany wheel :)
DIY Engine cover paintint
Fab it yurself! . . . . C clamp
DIY: Switch Panel by PCH.
DIY: New Key Handle
Door Buzzer Disconnect Switch
Page generated in 0.19506 seconds with 14 queries
