Go Back   Scion xB Forum > Scion xB DIY Articles > DIY Articles > Scion xB General
Old 09-13-2008, 12:05 PM   #1
grizzly_choppers's Avatar
DIY: Adding a door lock remote xB2
Just had to do this for a customer and had to make my tech print the instructions which I don't want to do again so I'll preserve it here for myself and my fellow xBers.
Prior to starting:
*No key in the igniton key cyliner
*The driver side door is open (other doors are closed)
*The Driver side door is unlocked
Proceedure:
*Insert and remove the tey into/from the ignition key cylinder twice (insert - remove - insert - remove) within 5 seconds.
The procedure should end with the key removed
Perform the following operations within 40 seconds.
*Close and open the driver side door twice (close - open - close - open)
The procedure should end with the door open.
*Insert and remove the key into/from the ignition key cylinder (insert - remove).
The procedure should end with the key removed.
*Close and open the driver side door twice (close - open - close - open).
*Insert the key into the ignition key cylinder and close all doors.
Perform the following operation within 40 seconds.
*Turn the ignition switch to on and then off one time (on - off).
*Remove the key from the ignition cylinder.
Locks will lock and unlock on their own.
*Within 40 seconds press the lock and unlock switches on the transmitter simultaneously.
*Preess lock OR unlock within 5 seconds.
Doors should lock and unlock themselves once (if they lock and unlock twice the operation has failed, try again from the start).
*Open driver's door.
*Insert key into the ignition cylinder.
DONE!!!
grizzly_choppers is offline
Old 09-13-2008, 12:10 PM   #2
Stark Industries
hotweelz4me's Avatar
Re: DIY: Adding a door lock remote xB2
Wow! This message will self distruct is 10 seconds. lol
hotweelz4me is offline
Old 09-13-2008, 12:35 PM   #3
bB626's Avatar
LOL!!! seriously!
so...once i did this on my brother's xB, and found out that he doesnt like it, how do i reset it to the way it is?
bB626 is offline
Old 09-13-2008, 01:04 PM   #4
Originally Posted by bB626 View Post
LOL!!! seriously!
All this proceedure does is add a door lock remote to the car (useful if you lose a remote and want to replace it or for some reason need a total of 3 or more). All function remains the same. Similar proceedures do other things to the lock system though.
What exactly did you do to your brother's car that he dislikes? Perhaps I can help.
-Alex
Old 09-17-2008, 07:31 PM   #5
hotBBox's Avatar
hotBBox is on a distinguished road
Send a message via AIM to hotBBox
damn thats harder then doing the custom greeting on my stereo.
thats some crazy stuff
hotBBox is offline
Old 09-18-2008, 01:03 AM   #6
FISH!!
Midnightmare's Avatar
Midnightmare is on a distinguished road
lol fo realz
Midnightmare is offline
Paint codes
DIY: ECU Reset w/o disconnecting the negative terminal
How To: Ship wheels and tires.
Zenesis E502 Install DIY xB Gen 1
DIY: How to make JDM look from a germany wheel :)
DIY Engine cover paintint
Fab it yurself! . . . . C clamp
DIY: Switch Panel by PCH.
DIY: New Key Handle
Door Buzzer Disconnect Switch
Page generated in 0.18404 seconds with 13 queries
