Old 01-24-2006, 08:24 PM   #1
Steering Wheel Install - OEM Install instructions added.
Took about 10min. to install.
1st pic. - stock wheel. Make sure you wheels are straight and battery is disconnected.
2nd pic. - using two pieces of tape, mark alignment marks, so that you will reinstall the new wheel in the same spot.
3rd pic. - using a T30 torx, loosen up this bolt on both sides. It won't come all the way out, it just loosins and stays attached to the covering.
4th pic. - with the two torx bolts loose, the air-bag assembly can be pulled loose.
5th pic. - with the bag loose, use a small flat blade screw driver and stick it where shown and pop-up the little yellow clip. (Just till it clicks)
6th pic. - disconnect the horn, by pinching this plug and pulling.
7th pic. - using a 19mm socket with a long extension and ratchet, loosen and remove the main bolt. (turn towards your left)
8th pic. - bolt removed.
9th pic. - using a phillips head screw driver, remove the two upper screws. (one on each side)
10th pic. - push the little keepers open on each side of the bottom of the wheel. This step & step 9 will loosen the plastic cover from the back of the wheel.
to be continued.
Padanky is offline
Old 01-24-2006, 08:35 PM   #2
these are some of the pics, didn't seem to work on the first post.
Padanky is offline
Old 01-24-2006, 08:37 PM   #3
more of the pics.
Padanky is offline
Old 01-24-2006, 08:40 PM   #4
11th pic. - grab both sides of wheel and pull & wiggle, comes right off.
put the new one on and reverse all the steps above.
12th pic - The new wheel installed!!!
The silver around the air-bag section will soon be gloss black, like the radio.
Padanky is offline
Old 01-24-2006, 09:19 PM   #5
It took me almost 20 minutes cuz I did mine at 1 o'clock in the morning!
Nice pictorial!
squirrel is offline
Old 01-26-2006, 07:19 PM   #6
RageStevens is on a distinguished road
Thumbs up
He He, Thats all.....Geez that looks easy. Man I was thinking it was hard or something. I have been a lil scared to do it. Thank you for a great write up.
RageStevens is offline
Old 01-27-2006, 12:37 PM   #7
daramg's Avatar
daramg is on a distinguished road
Send a message via AIM to daramg Send a message via MSN to daramg
Awesome... I can and will never do this myself but enjoyed the tutorial. Thanks!!
daramg is offline
Old 01-27-2006, 09:28 PM   #8
Long Live the Go-Go Box
Scion-Doll's Avatar
Scion-Doll is on a distinguished road
Send a message via AIM to Scion-Doll Send a message via Yahoo to Scion-Doll
Looking Good! It totally looks better in your xb! Thanks for the write up and pics.
Scion-Doll is offline
Old 04-10-2006, 12:48 AM   #9
Thumbs up
Thanks Chris!!
Old 04-13-2006, 06:04 AM   #10
RAIDERBEAST's Avatar
RAIDERBEAST is on a distinguished road
Any time you are messin with air bags its best to pull the airbag fuse first. FYI
RAIDERBEAST is offline
Old 06-20-2006, 10:22 PM   #11
BoXBoy's Avatar
BoXBoy is on a distinguished road
OK,
So where are you guys getting the steering wheels that fit the XB? Looks totally awesome! I have always wanted to change mine , but was afraid of a random 'bag deployment"
BoXBoy is offline
Old 06-20-2006, 10:31 PM   #12
ScottyTuned's Avatar
dude i owe you one big time Chris! i had no idea how to do this one before and was scared as hell i was gonna pop the air bag in my face! now time for modding.....
ScottyTuned is offline
Old 06-21-2006, 12:01 PM   #13
No prob! Really easy, 10 minutes. Just pull the battery or fuse, but if you pull the fuse don't start or turn the key on or it could set off your air bag light and you'll have to go to the dealer to get it turned off.
Chris
Padanky is offline
Old 07-30-2006, 09:52 PM   #14
Siver turned gloss black like promised!
Padanky is offline
Old 09-08-2006, 01:03 PM   #15
theboxboy's Avatar
theboxboy is on a distinguished road
Send a message via AIM to theboxboy Send a message via Yahoo to theboxboy
ok and how would you put a compleat new stering wheel?
theboxboy is offline
Old 02-12-2008, 08:04 PM   #16
Re: Steering Wheel Install
Added: Scion xB Steering Wheel Instructions.
Steering wheel with audio controls... glen619 Scion xB Audio, Video, & Security 24 06-22-2007 07:11 PM
CA: Scion Steering Wheel & Tail Lights Scion-Doll Scion xB Classifieds 34 05-19-2006 10:25 AM
Wheel Spacers BOXlover11 Scion xB Suspension, Chassis & Brakes 35 02-14-2006 09:59 AM
DIY: Covering the door panels
DIY headrest monitor install
Removing the Center Dash Trim
Custom Roof Console
DIY: Homemade Boo Boo's.
Ignition switch cover
Page generated in 0.23527 seconds with 14 queries
