08-11-2007, 01:24 AM
#1 | | Authorized Vendor
| Larger Tach, Shrunken Voodoo Speedo w/Pics Start by removing the gauge cluster from the dash:
There's a white plug on the back that needs to be disconnected and a black clip holding the wiring harness. The clip can be removed by gently pulling away from the cluster: To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
Then remove the 4 screws on the back of the cluster: To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
After that remove the white cover that houses the circuit boards by gently lifting up on the white clips. Then you'll see this: To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
Remove the tanish colored cable from the circuit board by gently pulling on it making sure not to place any stress on the board. Slice the outside two wires on each side of the cable and then slice the wires in sets of four for each of the gauges, going about 3/4 of the way up in the center of the plastic. You'll now have a pattern like this with the wires 2,4,4,4,2. Take the blue arrowed one and swap it with the red arrowed one. I hope this helps. I'll have more pics after I complete taz's car. |
08-11-2007, 01:40 AM
#2 | | Resident Rhode Islander
Join Date: Oct 2006 Location: La ville la plus française aux États-Unis
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics Sounds interesting..I can't wait to see more pics... |
08-11-2007, 01:43 AM
#3 | | Al Choholic
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics |
08-11-2007, 05:03 AM
#4 | | NEXT LEVEL MOTORING
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics jason does it again.
send it to DIY section NOW! |
08-11-2007, 10:56 AM
#5 | | Authorized Vendor
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
here's a face for it. |
08-11-2007, 01:25 PM
#6 | | Floating Around Somewhere
Join Date: Jan 2006 Location: In The South West Hanging With The SA Crew.
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics Another mod for Taz. Can't wait to see some finished pics. |
08-11-2007, 01:30 PM
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics Do you have the face in a print out version? |
08-12-2007, 02:30 PM
#8 | | bB Squad
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics That's gonna' look awesome!
Reason: totally radical fo' life!!
08-21-2007, 01:01 AM
#9 | | Haole Grandpa
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics Here is my finished product. Thanks Jason. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts. |
08-21-2007, 01:22 AM
#10 | | mobbin
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics taz if you do another tech day soon, let me know. im to scared to try this one haha. |
#11 | | Undercover Moderator
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics Quote: | To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
| So, is that one of the pics of Kelly when you two went to Hawaii? To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts. |
08-21-2007, 01:24 AM
#12 | | Haole Grandpa
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics Quote: | So, is that one of the pics of Kelly when you two went to Hawaii? To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
| She's gonna love you for that comment. Yup, she's my little Wahini. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts. Quote: | taz if you do another tech day soon, let me know. im to scared to try this one haha. | I watched Jason do it, it's not that tough. You need to get a new face though or it won't display right.
Let me know when you get a new one and it's on like Donkey Kong!
08-21-2007, 01:28 AM
#13 | | mobbin
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics i like the one that was posted earlier, it would match my ride with the black and red. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
it looks sickkkkkk. but where do i get a realistic size of it? |
08-21-2007, 01:34 AM
#14 | | Haole Grandpa
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics Quote: | i like the one that was posted earlier, it would match my ride with the black and red. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
it looks sickkkkkk. but where do i get a realistic size of it? | Jason has it on file, just tell him that's the one you want and he'll print it out. He is at all the meets so you could pick it up there. |
08-21-2007, 08:21 AM
#15 | | Floating Around Somewhere
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics Nice -- I like To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts. |
08-21-2007, 09:06 AM
#16 | | Authorized Vendor
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics I'm going to start offering the new faces and installs with the mod at the shows. |
08-21-2007, 09:33 AM
#17 | | Haole Grandpa
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics Quote: | I'm going to start offering the new faces and installs with the mod at the shows. | You better get you one of these... To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts. |
08-21-2007, 10:25 AM
#18 | | big papa
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics sweet mod now to figure what design i want for mine |
08-21-2007, 01:39 PM
#19 | | Registered User
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics Id like to see a digital conversion at some time. |
08-21-2007, 10:46 PM
#20 | | Oh My Gah! bB Squad Son!!
| Re: Larger Tach, Shrunken Voodoo Speedo w/Pics Great Mod and a great guy. Cant wait to pay for the face for mine. just need to get the wife to agree in the increase in car budget for the month To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts. |
