08-16-2006, 02:13 AM
#1 | | 06.5 TCM
| Ignition switch cover
08-16-2006, 12:20 PM
| Now thats what i'm talking about...nice |
08-17-2006, 01:16 AM
#3 | | Undercover Moderator
| That's modding in the truest sense of the word!
How 'bout a step by step to share with the family?  |
08-17-2006, 02:18 AM
| What?!? No LEDs?
Nice simple mod - I like! Well done.
Tomas |
08-17-2006, 02:30 AM
Join Date: Jun 2006 Location: Santa Clarita Valley, CA SCV
| Quote: |
| ditto
Looks good. Think you could paint it? (Even if it wouldn't hold up it might be nice for shows. . .) |
08-17-2006, 03:09 AM
| Quote: |
Originally Posted by Liesjemt ditto
Looks good. Think you could paint it? (Even if it wouldn't hold up it might be nice for shows. . .) | Hmmmmmm... for shows one just like that WITHOUT the hole punched in it would be nice...
Tomas |
08-17-2006, 08:17 AM
#7 | | That Guy
| Did you use glue or did it just snap on? Looks really good. |
08-17-2006, 09:50 AM
#8 | | Haole Grandpa Moderator
| Kind of like the directions on the furtiture you buy at Ikea. Pics but no words. Help a brotha' out...some narration? Please?
Tomas: Nice idea! |
08-17-2006, 10:51 AM
#9 | |
| base on the pics, its just a cap, maybe a motor oil cap? then he punch out the middle, size of the key hole, then cut and trim the edges into 2-3 mm?, probably glued it there.
btw, I like the camera used, it could probably capture and show an ant's facial expression.
08-17-2006, 01:10 PM
#10 | | That Guy
| It looks like a mobile 1 oil cap for the large containers. |
08-17-2006, 04:33 PM
#11 | |
| don't know how long will it stay like this, but I just polished mine today  |
08-17-2006, 04:38 PM
| If yout paint it the keys will rub it or scratch it off. |
08-17-2006, 08:48 PM
#13 | | 06.5 TCM
| It's indeed a Mobil 1 cap. Ill take some more pics to show how much clearancing has to be done on it. It just snaps in and is held by the shroud.
I dont know if that plastic can be painted, but I've also seen Mobil 1 caps in Red and Green (Envy  ). The material that those caps are made of is very scratch resistant. The silver one is a PERFECT match to the inserts on the steering wheel. |
08-18-2006, 11:34 AM
#14 | | Undercover Moderator
| Quote: |
Originally Posted by PCH It's indeed a Mobil 1 cap. Ill take some more pics to show how much clearancing has to be done on it. It just snaps in and is held by the shroud.
I dont know if that plastic can be painted, but I've also seen Mobil 1 caps in Red and Green (Envy  ). The material that those caps are made of is very scratch resistant. The silver one is a PERFECT match to the inserts on the steering wheel. | Please post up a how-to! I've already polished mine, but yours looks sooooo much cleaner!  x2 |
08-18-2006, 11:27 PM
#15 | | 06.5 TCM
| Thanks to everyone for positive feedback. Here is the DIY in pics. IKEA style  . Just general guidelines: Regular Mobil1 1qt oil cap, use sharp tools, clean up with 400 grid sandpaper, spoil as many caps as you wish. For this DIY I used 9/16 hole punch. Inner depth of the cover is .250 in min. The thinner you make the sidewall (i used Dremel) - the better your chances of the steering column shroud not splitting at the halves.
08-18-2006, 11:58 PM
#16 | | Registered User
| ‘Nuff said.
Best DIY ever.
Ever.  |
08-19-2006, 12:20 AM
#17 | | Registered User
| Absolutely excellent DIY! No questions left.
Tomas |
08-19-2006, 02:04 AM
#18 | | Undercover Moderator
| Thank you very much!
It gets my vote as mod of the month!! |
08-19-2006, 02:42 AM
#19 | | Haole Grandpa Moderator
| Wow WOW!
That's how a DIY is meant to be done! Thank you. Awesome!  |
08-19-2006, 10:11 PM
#20 | | That Guy
| Genius. Just plain genius. |
