05-09-2006, 04:22 PM
| How To: Install Superfa's LED Bottom Bezel I just got this part from Superfa and just wanted to do a how to cause they didn't have one..
Lets get started.
First you want to disconnect your battery positive terminal before attempting to do this install.
Unscrew the shift knob. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
Take the carpet fabric out of the rear cup holder and unscrew the bolt with a Philipes Screw Driver. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
Pop off the console cover. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
To take off the console pull the front of the consolre upward. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
There are two white fasteners in the front of the console. Make sure they are attached to the console. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
Now take your console to your work space and flip the console upside down. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
You will see the taps that hold the bottom bezel onto the consle. Pull the taps inward and take off the bottom bezel. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
With the bezel still upside down take out the shift boot, it is held in buy a metal ring that snaps out. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
I used a different shift boot but go ahead and snap the shift boot onto the new bezel. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
Your New bottom bezel and shift boot should look something like this. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
Now take the new bezel and snap it on to the console. To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
Now put everything back together in your car and find a way to power up your bezel.
Now as for lighting it up there are many different ways to do this. I have all of my light ran to a switch so I just pluged it into that. You can also tap into the cigarette lighter for a power source. Buy doing this the bezel will only come on when a key is in the "power" position in the ignition.
Here are some pics To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts.
I also want to say thanks to Shawn at Superfa for letting me be one of the first people with this part.
05-09-2006, 04:37 PM
#2 | | Haole Grandpa
| Looks superfa! To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts. |
05-10-2006, 09:13 PM
| This part is not on their site!
I have the shift bezel but no bottom bezel.
How much was this part?
I need this in orange! |
05-10-2006, 10:41 PM
05-11-2006, 12:35 AM
| I would talk to them. They said that the bottom bezel should be out. # 407-902-9488 or To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts. |
06-06-2006, 04:55 PM
#6 | | Scion Apocalypse SoCal
01-08-2007, 12:09 PM
| where did u get the lights for the subs, and for how much? |
01-14-2007, 01:08 AM
| Quote: | where did u get the lights for the subs, and for how much? | I got the light from ebay. I don't remember how much, but the price wasn't to bad. It comes in a couple of different colors, and they have 10" & 12" subs. |
01-15-2007, 03:42 PM
| I fixed the pix if anyone cares. |
01-17-2007, 01:55 PM
#10 | | Registered Abuser
| that was a cool walk through, its something ill probably never do but it was a damn good instructional. allthough those little lights in the door locks are neet. where did you come up on those from? |
01-17-2007, 07:37 PM
| Quote: | that was a cool walk through, its something ill probably never do but it was a damn good instructional. allthough those little lights in the door locks are neet. where did you come up on those from? | To view links or images in this forum your post count must be 30 or greater. You currently have 0 posts. |
04-08-2007, 10:23 AM
| Re: How To: Install Superfa's LED Bottom Bezel i just won the bottom shifter bezel off ebay is the install the same for autos?
04-09-2007, 12:02 AM
| Re: How To: Install Superfa's LED Bottom Bezel Quote: | i just won the bottom shifter bezel off ebay is the install the same for autos? | It should be, nothing to hard. |
04-10-2007, 03:53 PM
#14 | | Registered User
| Re: How To: Install Superfa's LED Bottom Bezel i installed one on my auto. a little bit of trimming was needed but it was well worth it |
04-10-2007, 04:41 PM
#15 | | Registered User
| Re: How To: Install Superfa's LED Bottom Bezel what kind of trimming was necessary? |
04-23-2007, 08:13 PM
#16 | | Registered User
| Re: How To: Install Superfa's LED Bottom Bezel hmm i just spent over an hour trying to install the bottom bezel on my auto, couldnt get it to fit it seems theres something underneath that does not fit right. emailed superfa but they're not responding. in the auction it said specifically that it fit auto or manual but i'm guessing thats not the case. |
04-24-2007, 03:24 AM
#17 | | Registered User
| Re: How To: Install Superfa's LED Bottom Bezel Quote: | i installed one on my auto. a little bit of trimming was needed but it was well worth it | how much trimming was there, can you help a fellow member out? |
04-24-2007, 12:43 PM
#18 | | Registered User
| Re: How To: Install Superfa's LED Bottom Bezel awesome walkthrough. Just bought top and bottom bezels. I have stealer installed leds under dash and in cup holders. They're on a switch. (1)Can I "T-Tap" the power going to that switch and run it to another switch for the two bezels? (2) do i need an inline fuse here somewhere? If so what size?
Thanks |
04-24-2007, 03:32 PM
#19 | | Registered User
| Re: How To: Install Superfa's LED Bottom Bezel well as for the trimming it has been awhile. i used a dremmel tool and took a little bit off the piece of plastic the bezel fits onto, not the bezel itself. Sorry I am not much help. It pisses me off that they market this product for an auto and it doesnt fit right. I am not going to dis the company but they should say some trimming is required. They never got back to any of the emails I sent them when my product didnt fit.
Whatever you do dont force it on even the smallest crack and the LEDs will stop working!!!!!!! I had to have mine repaired. |
04-25-2007, 03:01 AM
#20 | | Registered User
| Re: How To: Install Superfa's LED Bottom Bezel Quote: | awesome walkthrough. Just bought top and bottom bezels. I have stealer installed leds under dash and in cup holders. They're on a switch. (1)Can I "T-Tap" the power going to that switch and run it to another switch for the two bezels? (2) do i need an inline fuse here somewhere? If so what size?
Thanks | Yes you can tap it into the power going to the switch for your other LED's. And the cup holder led should already have a fuse, if it dosent the you should add one. |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Scion xB Forum | Replies | Last Post | | Help with project lights install | randkgifts | Scion xB Lighting & Electrical | 1 | 06-08-2006 03:44 PM | | | |
