Old 09-28-2007, 08:25 PM   #1
goyogi is on a distinguished road
I got this idea from the echodrivers.com forum.
I replaced the wiper stalk/switch with one from a 2004 Pontiac Vibe which is basically a Toyota Matrix. The only difference is that this has VARIABLE intermittent speeds.
Now I have 2,4,6 and 8 second delays. It's much more useful. Every fuction works except the Vibe/Matrix has a two speed rear motor that this switch does not work with. So the low speed rear wiper position does not work. But the high speed rear wiper position works like normal. Apparently you need the motor from a Vibe/Matrix to get the two rear speeds to work. Not enough incentive for me to do that.
I got the switch from a 2004 Pontiac Vibe. I chose the Vibe because ALL models came with Variable intermittent wipers and the parts guy would have a hard time screwing it up. Some of the base Matrix models came with NO variable intermittent speed switches.
I apologize for the grainy photos. There was low light and I used my camera phone. But it's VERY easy to do. It took me less than 10 minutes.
Here's the How To
1) Admire new switch
2) Remove screw underneath steering column
3) Turn steering wheel 90 degrees to the right and remove the hidden screw. Do the same on the left.
4) Pull down plastic steering column cover and then pull up on the top part. They are held in place with plastic tabs. So just give it a good tug and they'll come apart.
5) Use a small flathead screwdriver to press the tab on the wiring harness and pull down on wiring harness.
6) Use the same screwdriver to press on the front tab of the switch and the slide the switch out.
7) Slide new switch in, plug in harness and test. If it's all good, then put back the steering column together and you are done!
goyogi is offline
Old 09-28-2007, 08:41 PM   #2
Re: DIY Variable Intermittent Wiper Install
Nice post!
Old 09-28-2007, 08:51 PM   #3
Most excellent! Thank you.
Old 09-28-2007, 09:24 PM   #4
RS4 #303
sdsnybny's Avatar
way cool how about the part # for the switch you ended up with if you would
sdsnybny is offline
Old 09-28-2007, 10:00 PM   #5
bB626's Avatar
very nice!!!
bB626 is offline
Old 09-28-2007, 10:16 PM   #6
Hella Bastos
gnarly post!!
ketchup_xb is online now
Old 09-28-2007, 10:23 PM   #7
FUSCION Car Club
Gumby29's Avatar
Gumby29 is on a distinguished road
Send a message via AIM to Gumby29 Send a message via Yahoo to Gumby29
Awesome idea... yeah, i hate our stock wiper switch...
Gumby29 is offline
Old 09-28-2007, 10:42 PM   #8
Part number is a GM part number 88969651. At least that's what's on the shipping form. 2004 Pontiac Vibe wiper switch. I think it's the same through 2006 or so. I just figured my car is a 2004 so get a 2004 switch.
Also you'll find that though it's identical to the Matrix switch the GM one is cheaper. I got it through my roommate's friend who works at a dealer and get's parts at cost +10%. So it cost me about $50. I think cost is about $45. The cheapest I found online was about $60.
They can be found at junkyards or ebay for around $25 but I don't have the time these days to do that.
goyogi is offline
Old 09-28-2007, 11:01 PM   #9
bB squad
HotBox009's Avatar
HotBox009 is on a distinguished road
Wow, i would never think of that mod. Very awesome.
HotBox009 is offline
Old 09-28-2007, 11:21 PM   #10
Using the part number given I'm coming up with something different than what you show in the first picture. Did that all come as one piece?
Old 09-28-2007, 11:50 PM   #11
FUSCION Car Club
Gumby29's Avatar
wait, so all that timing difference is only from that switch??? its not actually from the motor??? wow, i didnt know that... i still have a lot to learn...
Gumby29 is offline
Old 09-29-2007, 01:11 AM   #12
bBsquad reppin
dancar420's Avatar
dancar420 is on a distinguished road
damn that is a nice mod and cheap too
dancar420 is offline
Old 09-29-2007, 04:06 AM   #13
orcas1013's Avatar
orcas1013 is on a distinguished road
Send a message via AIM to orcas1013
now if only we could steal the cruise conrol off the vibe too :0)
orcas1013 is offline
Old 09-30-2007, 01:14 AM   #14
Yeah, sorry, on the printout that is what the part number said but I don't think it's the right number. I had a difficult time finding the part number. That's why I went with the 2004 Vibe because they ALL had variable intermittent wiper switches and they are cheaper than the Matrix. So no mix up with the parts person or the junk yard if you go that route.
So just ask a Pontiac supplier for a wiper switch/stalk from a '04 Vibe. And they should be able to find it. It's all one piece.
JJ
Yeah, cruise control, variable intermittent wipers and torque are what I miss most from my last car.
One down, two to go. I plan on fixing both next year if all goes well. Stay tuned.
goyogi is offline
Old 10-04-2007, 10:39 PM   #15
xbdave's Avatar
xbdave is on a distinguished road
Has anyone tried using a stalk from another Toyota, like a Highlander or Forerunner, etc. that has the rear wiper feature? Pics I have seen, they seem to look to be the same part?
xbdave is offline
Old 10-06-2007, 09:29 PM   #16
Supposedly some years of the Rav4 will swap out. I'd stick with 2004-2006 years like our xBs if you are to try and swap it out. If you know any friends/family that has one try and swap it out and report back.
If you are looking at new, stick with the Pontiac. It's "american" so it's cheaper, though it's the same part.
If you are looking in junkyards or ebay I wouldn't spend more than $25.
goyogi is offline
Old 10-08-2007, 06:10 PM   #17
kzhorse's Avatar
kzhorse is on a distinguished road
I may be wrong but if you get it from a junk yard look in the rear near the wiper for a relay so the 2 speed works on the rear of the xB.
Scott
kzhorse is offline
Old 10-08-2007, 06:12 PM   #18
XrayBravo
hawkinsjd11's Avatar
hawkinsjd11 is on a distinguished road
pffff, I don't need windshield wipers!!
hawkinsjd11 is offline
Old 11-13-2007, 11:03 PM   #19
xbdave's Avatar
[quote=goyogi;220359]I got this idea from the echodrivers.com forum.
I installed a Vibe switch as well. Real easy and works like a charm. Found the switch at Pam's Auto Recycling in Minnesota. www.pamsauto.com . Couldn't find anything in any boneyard around here. Just happened upon it one night doing a Google search.
diy-variable-intermittent-wiper-install-windshield-wiper-vibe-pt3.jpg  diy-variable-intermittent-wiper-install-windshield-wiper-vibe-pt2.jpg
xbdave is offline
Old 11-13-2007, 11:41 PM   #20
Very useful! I hate hitting the switch every 10 sec when its misty.
PCH is online now
DIY: Covering the door panels
Removing the Center Dash Trim
Custom Roof Console
DIY headrest monitor install
Ignition switch cover
DIY: Homemade Boo Boo's.
Page generated in 0.24243 seconds with 14 queries
