Decided to swap out my PRINDLE. Figured i would share.
First things is you will need a few things.
You will need a screwdriver and your new prindle from xbcustomgauges.com.
First remove this screw.
Then set your parking brake and pull up on the panel below it.
Unclip the wires underneath.
Now lift up on the console, it has to white plugs on the front that pop out. be careful not to pull out your cup holder lights (if applicable). set console out of the way.
Next, unclip the assemply. there are six clips. two on the front and back and one on each side.
Now slide the prindle out from the top by prying it from the passenger side.
Remove the bulb on the driver side and take the green boot off then replace the bulb. Now re-install in reverse order and you are done.
BEFORE:
AFTER:
Any questions feel free to PM me
