Ok so here are some pics still need to figure out how I'm gonna mount to th ceiling to replace the dome.
#1
#2
#3
#4
And in the holes will be mounted super white LED bulbs.
#5
On this pic you can see where i chewed out the center of the symbol for the wires
#6
And on this you can see where the power suply will go through in the hole on the right..
#7
#8
So now all I have to do is wait till I redo my headliner and mount it.
If i can figure out how to. Keep in mind it is going to be a finish product and the plexy is clear
Edit: So I am going to use two peices of flashing one cut in the shape of an oval smaller than the biggest part on the bevel and the other as backing. plus the lighting will reflect off the flashing once finished.
