Hey whats up,
I'm gonna tell you guys how to wire in your radar detector for a clean finished look and for the option of using your ciggarette lighter for a charger, etc...
tools needed:
1 screwdriver
1 pair of wire cutters/ strippers
1 wire krimp
here we go...
first cut the biga$$ ciggarette male fitting off
thier should be a positive(red) and a ground wire (white or black). pull them back so that you have 5" of both of them then strip the ends
First find the big white wire with a blue pinstripe: this is your 12 volt constant wire. Connect the red to this wire via wire krimp..( in this I have a red extension coming off of the white/blue.
it's that easy, one more to go connect. find the other 5" wire and connect it to the ground that hold the fusebox.
goodbye big bulky ciggarette lighter module
hello cleanliness, the 12 volt constant will give you all control over the unti and you will be responsible for turning it on and off. I chose to do this rather than the ignition wire so i will be able to turn it on even when the car is off.
hope this helps...
