Old 05-23-2009, 07:29 PM   #1
DIY:Door lock lever removal and install Gen1
Simple removal of the OEM and installing the NIGHT WERKS Chrome door lock lever.
Work time: 10-20min.
Mechanical level:1
(1-if you have a screwdriver/10-skilled mechanic)
OEM door lock lever
You’ll need to remove/loosen the door cap/panel to remove the door lock lever.
Remove 3 screws that hold the door cap/panel to door using proper screwdriver.
The third screw by the inner door jamb is plastic and needs to be unscrewed and pulled out.
Next you’ll need to pull door cap/panel away from door. Door cap/panel is held on by plastic door cap/panel clips.
Start from the bottom of door by pulling the cap/panel edge with fingers and pull firmly away from door. (watch yer head.)
You’ll need to loosen all the bottom clips in order to push up the cap/panel and to pull the top away from the door lock lever without having to remove the whole cap/panel.
Pull top portion of door cap/panel away from the door lock lever to gain access and to unscrew lock lever.
Attach/screw on NIGHT WERKS Chrome door lock lever. Do not over tighten door lock lever. Also gauge the position of height of door lock lever when open/closed position to match the rest of the door lock lever. (Do not close door when door cap/panel is loose.)
Reinstall door cap/panel in reverse.
Finished.
SAKURA is offline
Old 05-23-2009, 09:56 PM   #2
OMG Pancakes
TheReaper's Avatar
TheReaper is on a distinguished road
Re: DIY:Door lock lever removal and install Gen1
Nice right up looks great man
TheReaper is online now
Old 05-23-2009, 10:01 PM   #3
JDM pawn shop
big_hungry's Avatar
big_hungry is on a distinguished road
Send a message via AIM to big_hungry Send a message via Yahoo to big_hungry
added note . if you pull a little to hard like i did and break a tab. you can easily replace them. Just go to your local dealership parts dept and pick up some.
big_hungry is offline
Old 05-23-2009, 10:09 PM   #4
The Tattoo Guru
TattooAl's Avatar
is there a website for nightwerks?
TattooAl is offline
Old 05-23-2009, 11:26 PM   #5
Chrome pins and handles: match made in heaven!
Clean and simple mod- can't be too lazy to do it
PCH is offline
Old 05-23-2009, 11:47 PM   #6
LOW!!!
xBtony's Avatar
Dang! Great write up (I need it fer a totally different reason..AHah) But those are some really sexy covers..and the best part is that there not covers..Lol..There replacments..Im impressed
xBtony is offline
Old 05-24-2009, 01:01 AM   #7
here ya go, talk to jason hes got alot of goods on his website. tellem eric sent ya.
Custom xB Gauges
SAKURA is offline
Old 05-24-2009, 08:48 AM   #8
The Tattoo Guru
TattooAl's Avatar
Custom xB Gauges
cool thanx!
TattooAl is offline
DIY: Covering the door panels
Removing the Center Dash Trim
Custom Roof Console
DIY headrest monitor install
Ignition switch cover
DIY: Homemade Boo Boo's.
Page generated in 0.19493 seconds with 13 queries
