Old 10-11-2008, 12:41 PM   #1
#2071
GRNBOXTER is on a distinguished road
DIY: Broken Window Control Housing
this is my first DIY so please be nice to me. i did this months ago and i didn't have a camera at the time. so i took my door apart and took some pics.
if you break the little tab that holds the housing in you can do what i did.
i took a old piece of 1 1/2" pipe and cut it up and ended up with this.
i took the pipe and cut off a small piece then cut it in half so i had to half "moons" if you want to call it that. then drilled holes into one end so i could use the two screws that were on the housing. then i kept on trimming off a little bit at a time until i got the perfect size. it turned out to be about a 1/4 of the pipe.
make sure it hangs a little bit past the housing so it can grab onto the door. it will look like this.
when you go to put it back in put the PVC side in first.
when you get it in there it will slide a little bit so you can snap the other side in.it will grab onto the door like this.
Now you have a window control that you will never know it was broken. i forgot i did this because it is so solid.
for the other ones i don't know how to fix. all of my other ones are not broken but that is the best i can do with the driver door. i think the pass front do has the screws too but i know the back doors do not. so you are on your own there.
GRNBOXTER is offline
Old 10-11-2008, 01:06 PM   #2
Re: DIY: Broken Window Control Housing
10+! McGyver style FTW!!!
PCH is online now
Old 10-11-2008, 01:53 PM   #3
beanzermin's Avatar
beanzermin is on a distinguished road
not a bad idea. i broke my drivers side more than once i just use some super glue. the one i used to is to hold a cracked bumper together so it can be repaired. works awesome cant tell the difference
beanzermin is offline
Old 10-11-2008, 02:03 PM   #4
narconethree is on a distinguished road
Send a message via AIM to narconethree
That is a darn good idea!
narconethree is offline
Old 10-11-2008, 03:42 PM   #5
you get a rep points for McGyvering it!
good job.
SAKURA is offline
Old 10-11-2008, 04:22 PM   #6
DJ's Daddy
litos_2006's Avatar
nice diy definite rep points
litos_2006 is offline
Old 10-11-2008, 05:19 PM   #7
swangin 4rm lane 2 lane
ToyBox_02's Avatar
nice diy my driver side is tha same way
ToyBox_02 is offline
Old 10-11-2008, 06:27 PM   #8
phillys phattest
Big_Jim's Avatar
Big_Jim is on a distinguished road
Send a message via AIM to Big_Jim
the place that did my leather broke my drivers side, and its been like that for over 3 years now. i think i may have to fix it!!
Big_Jim is offline
DIY: Covering the door panels
Removing the Center Dash Trim
Custom Roof Console
DIY headrest monitor install
Ignition switch cover
DIY: Homemade Boo Boo's.
Page generated in 0.17620 seconds with 13 queries
