Old 05-18-2009, 03:19 AM   #1
DIY: Airbag Delete Resistors (underdash)
This shows how to install airbag delete resistors into the spiral cable connector under the dash. There is another DIY that shows how to put them into the hub, but sometimes that's a little difficult because of lack of space. So if you made the choice to loose your airbag and run an aftermarket steering wheel here is another option on turning off the SRS warning light.
You will need two resistors 3 Ohms each and some 20 gauge wire to make plug-in harness.
Solder wire to the resistor:
Tin other ends with solder and use flat section of the pliers to flatten them:
Use heatshrink to insulate everything. This is a finished harness (you need two):
Unplug the connector from the spiral cable:
Insert resitor harnesses:
Secure everything with zipties or electrical tape and tuck in a safe location under the steeing column cover:
Use normal precaution: disconnect the battery before working on the car. As always, you understand what you are doing and it's your decision whether to follow this DIY or not.
PCH is offline
Old 05-18-2009, 07:21 AM   #2
Suspension Whore
859Toaster's Avatar
Re: Airbag Delete Resistors (underdash)
Another solid useful and detailed diy!
859Toaster is offline
Old 05-18-2009, 10:15 AM   #3
RS4 #303
sdsnybny's Avatar
Clean and loaded with good pics/details..............
sdsnybny is offline
Old 05-18-2009, 10:36 AM   #4
eggie is on a distinguished road
Now this is some good info. Good job on the details!
eggie is offline
Old 05-18-2009, 11:46 AM   #5
vettereddie's Avatar
vettereddie is on a distinguished road
Very nice write-up. Has anyone done this for the seats though? I need to pull my passenger front seat and don't want the airbag light on in the dash. Would also be nice if the driver airbag worked properly still.
Yes, I've done searches but still came up empty handed.
vettereddie is offline
Old 05-18-2009, 02:01 PM   #6
I believe you have 06.5, right? The passenger seat system on those includes 4 sensors, belt buckle switch and ECU. You should be able to remove the ECU from the seat along with wires and leave it connected to the car. 4 sensors and belt buckle switch can be replaced with resistors if you don't want to leave them all connected.
PCH is offline
Old 05-18-2009, 05:09 PM   #7
Re: DIY: Airbag Delete Resistors (underdash)
Yeah, I could pull them from the seat but they are part of the permanent structure and not removeable. The seat won't be out all the time so I'm looking for a solution that would be swappable. I was thinking of finding a second seat and pull the sensors from the second seat instead.
Old 05-18-2009, 06:11 PM   #8
To make a quick swap harness you'd need a donor seat out of 06.5 with at least wiring harness and occupant classification ECU in it. Sensors can be substituted with 1 MOhm resistors and for belt buckle you need 330 Ohm if i remember correctly. Factory repair manual lists all the values, you can double check there.
PCH is offline
Old 05-18-2009, 07:00 PM   #9
Staticlink05's Avatar
Staticlink05 is on a distinguished road
Send a message via AIM to Staticlink05
just freakin awsome!!! this will be very useful for when i get rid of my stock wheel!!!
Staticlink05 is offline
Old 05-19-2009, 12:51 PM   #10
Thanks, I'll be looking for a donor seat on car-part or if anyone's selling their stock ones. Forgot to mention, I have the regular 2006, not the 6.5 and do have a wiring diagram for it. I only have the repair manual for the 2004.
Old 05-19-2009, 02:09 PM   #11
Didn't i see audio controls on the steering wheel in your car? That woud make it 06.5. Where is your pass airbag light located? If it's under the owen then it's the last version (after Dec '05 production).
In any case the values should be same (1M and 330).
PCH is offline
Old 05-20-2009, 01:53 AM   #12
good stuff, great member, victor doing it once again!
now i can get rid of my black tape.
rep. points comming yer way!
SAKURA is offline
Old 05-20-2009, 02:09 AM   #13
LOW!!!
xBtony's Avatar
^What he said!
Now I just need to get a new wheel
xBtony is offline
Old 05-25-2009, 10:01 AM   #14
Never Stops
Digidizzle is on a distinguished road
Send a message via AIM to Digidizzle
This is awesome! I'm gonna be switching up soon.
Is there any wattage rating on the resistors you used?
Digidizzle is online now
Old 05-25-2009, 03:56 PM   #15
I used 1/4 Watt, but you can use higher rated resistors like 1/2 or 1 Watt. They are just larger in size.
PCH is offline
Old 05-28-2009, 04:33 PM   #16
southsidex13
bbscionxb's Avatar
bbscionxb can only hope to improve
will this work on the passnger one 2
bbscionxb is offline
Old 05-28-2009, 05:55 PM   #17
My guess is that resistors will probably be of the same value for the passenger airbag.
PCH is offline
Old 06-15-2009, 12:00 AM   #18
This DIY shows one of the ways not to have the SRS light On due to the previous removal of the driver side airbag. Installing the resistors does not take away from the safety. You may want to read the first post. I am not telling anyone they should disable SRS or parts of it. As far as legailty, that depends on the use of the car (racetrack, show, offroad or street) and local laws.
PCH is offline
DIY: Covering the door panels
Removing the Center Dash Trim
Custom Roof Console
DIY headrest monitor install
Ignition switch cover
DIY: Homemade Boo Boo's.
Page generated in 0.27493 seconds with 13 queries
