Old 11-18-2009, 04:11 PM   #1
scvscions's Avatar
DIY-2nd Gen Interior Lights R&R
the main one is pretty straight forward, just remove the lens and push in on the two plastic clips on oppisite edges of eachother. To get the wiring out you have to pop the box off that is just pushed on. The front light is simple as well:
To get the light out there are clips a 1/4 in on all four sides
just pry down and it will release:
The wire connector is straight forward. To get the lenses out you'll have to pry them loose from the center out carefully but as you can see the light bulbs are removed from the backside.
scvscions is offline
DIY: Covering the door panels
DIY headrest monitor install
Removing the Center Dash Trim
Custom Roof Console
DIY: Homemade Boo Boo's.
Ignition switch cover
Page generated in 0.16544 seconds with 13 queries
