Old 11-18-2009, 02:48 PM   #1
scvscions's Avatar
DIY-2nd Gen Grab Handle Re-assembly
Kind of tricky. To remove use a small flat screwdriver and pry the two plastic push clips out then squeeze the metal clip and pull out the handle:
To install, start by removing the metal clips from their spots (this is harder than it looks)
Insert the clip into the grab handle from the back side
It should set into place like this:
Insert the push pin:
Do the same for the rest, it will look like this when finished:
Then push the grab handle into place and you're done.
If you've ever taken these apart and then tried to put them back you know what a good DIY this is
scvscions is offline
Old 11-18-2009, 04:22 PM   #2
bB626's Avatar
Re: DIY-2nd Gen Grab Handle Re-assembly
whoa! thats crazy! those are held by clips?
thanks for the info, Jason!
bB626 is offline
DIY: Covering the door panels
DIY headrest monitor install
Removing the Center Dash Trim
Custom Roof Console
DIY: Homemade Boo Boo's.
Ignition switch cover
Page generated in 0.16912 seconds with 13 queries
