Old 04-26-2009, 12:26 AM   #1
scvscions's Avatar
DIY 2nd Gen Door Panel and Mirrior R&R
The first screw is in the door handle pocket:
Pull up on the assembly and remove the wiring:
Next you have to remove the plastic piece behind the door handle to find the next screw:
Pull out the tweeter triangle and remove the wiring:
Next grab the door from the bottom, you'll feel an area for your hand, and pull from the bottom up. These doors are tight on there with the clips but they come loose. Watch the wiring at the top and watch where all of the white clips go if any decide to pop off when you take the panel off:
Don't pull the door all the way off, you're not done yet, here's the door handle which is now clipped to the door:
Pull down and twist it out and you can remove the panel:
If you want to take the mirror off, un clip the wiring here and remove the three 10mm bolts:
scvscions is offline
Old 04-26-2009, 12:58 AM   #2
Re: DIY 2nd Gen Door Panel and Mirrior R&R
once again, the first to ever strip a gen2 to down to frame. good job jason.
SAKURA is offline
Old 07-07-2009, 11:31 PM   #3
Kurtis W
kurtiswiersma is on a distinguished road
Send a message via AIM to kurtiswiersma
anyone have any close up shots on the speaker? I am looking to put some LED's in the speaker but wanna see what everything looks like on the inside.
kurtiswiersma is offline
Old 07-09-2009, 11:39 AM   #4
MasterVader
StykShift's Avatar
yo! we gotta just take the door apart to see how to lay down the led strip....i can't wait, its gonna be so much fun!
StykShift is offline
Old 07-09-2009, 12:50 PM   #5
Kurtis W
I figured it out! Im gonna post some pics and a DIY on it next week!
Old 07-09-2009, 06:23 PM   #6
scvscions's Avatar
here's a close up
see new thread for more pics
Old 07-09-2009, 10:43 PM   #7
MasterVader
StykShift's Avatar
bring it on kurt!!! can't wait to see the new mod!...
DIY: Covering the door panels
Removing the Center Dash Trim
Custom Roof Console
DIY headrest monitor install
Ignition switch cover
DIY: Homemade Boo Boo's.
Page generated in 0.19990 seconds with 13 queries
