Old 04-26-2009, 12:25 AM   #1
scvscions's Avatar
DIY - 2nd Gen Dash Removal
DISCONNECT THE BATTERY!
Let's see here, first take out the gauge (you can see the DIY for that) and pop out the center vents ( just four pink clips ) and pop the facia board in front of the driver (some more clips). Remove your radio and unplug it as well. If you have Navi remove the antenna that's on the vent under the center part of the dash. Remove the A pillars by pulling them toward the dash, don't worry they will stop as Scion has added a new clip that you need to twist with a small pair of pliers and clock it out at a vertical angle (so I cut them):
Here's the two screws on either side of the radio that need to be gone:
And the one on top, driver's side of the gauge cluster:
Remove the glovebox and look up. There's a 12mm silver bolt holding the passenger side airbag, and the airbag is connected to the dash. The airbag wiring is yellow, gently remove the clip and unclip the wiring, DO NOT tug on the wires, but the connector is fine.
Then you can pull your dash out for whatever you'd like to do.
scvscions is offline
Old 04-26-2009, 12:55 AM   #2
Re: DIY - 2nd Gen Dash Removal
once again, the first to ever strip a gen2 down to frame. good job jason.
SAKURA is offline
Old 05-25-2009, 06:58 PM   #3
Zujo is on a distinguished road
great info! but next tie try using big clear pictures because having them so small might throw off some users.
Zujo is offline
Old 05-25-2009, 08:46 PM   #4
click on pics to enlarge photo......... like so
SAKURA is offline
Old 05-25-2009, 09:02 PM   #5
shawnofthedead420's Avatar
^^^^^^ahahahahhahah. thats some good stuff right there. great job jason. im glad to see that i was wrong about assuming there were only two screws holding the dash together. 5 screws, YES!
shawnofthedead420 is offline
DIY: Covering the door panels
Removing the Center Dash Trim
Custom Roof Console
DIY headrest monitor install
Ignition switch cover
DIY: Homemade Boo Boo's.
Page generated in 0.22837 seconds with 13 queries
