Old 02-06-2006, 12:35 AM   #1
clubxbdave is on a distinguished road
Custom Roof Console
Done this June of 2004, lost the pix, but then I found it again. just want to share and give others the idea.
Disclaimer: all things you do on your car is your responsibility, this is just a guide and not meant to follow word per word.
Okay, I didn’t really took me 5 hours to finish it. More likely 1 hour tops. If you have all the stuff ready, then its easy.
Materials
1 maplight housing
3 color coded wires, close to stock guage, length from front to middle of headliner
2 wire tap, 1 C-butt, 3 wire butt
1 half inch thick wood (depend on how wide the distance of the securing screws are)
1 metal epoxy
masking tape
card board for template(fedex envelop wil do)
black/gray foam, fire/heat retardant, like those you find on computer packaging
Tools:
Screw driver, Exacto knife, wire cutter splicer , butt crimper
I initially wanted the head console for Mitsubishi Montero Sport(wife’s ride) but can’t find one, so I ended up getting this(Nissan Quest I think). It doesn’t really matter, you might want to look for a better one.
First, I made a template of the underside of the housing, the part that’s going to go inside the headliner.
Mask the part, trace, then cut. Before cutting, make sure its align.
Then finding that the depth is not enough, I made a foam spacer, to push the headliner down so it will meet with the housing edge.
Theres a piece of insulator foam that is glued under the roof that I took off so I can epoxy the wood from where the securing screws will be.
Test mount the housing, then mark points where screws goes, then drill small holes(for easy screwing). Make sure the drill is less than half inch.
Wiring
The center lamp has blue wire(power), red wire(door ground), and any of the 2 screws for ground.
Fish 3 wires from front to the center lamp hole.
I tap the 2 wires, then used C-tap to connect it on one of the screw that hold the center lamp. Then butt connected the other end(front) of the wires to the map light harness. Please note that I have to do trial and error to make the lightings work the way they should. One thing good about working with this bulb, is they don’t have polarity, so no chance of burning it.
Hope this helps.
clubxbdave is offline
Old 02-07-2006, 12:36 PM   #2
JF_VIKINGSFAN's Avatar
JF_VIKINGSFAN is on a distinguished road
Sweet! It looks great, I think I will have to do something like this too.
JF_VIKINGSFAN is offline
Old 02-07-2006, 05:05 PM   #3
R_lilbox's Avatar
R_lilbox is on a distinguished road
nice! i was thinking of putting one in for couple months now. nice work
R_lilbox is offline
Old 02-08-2006, 10:46 AM   #4
caden_stargate's Avatar
caden_stargate is on a distinguished road
Send a message via AIM to caden_stargate Send a message via MSN to caden_stargate Send a message via Yahoo to caden_stargate Send a message via Skype™ to caden_stargate
Wow that's awesome looks like it came with the car.
caden_stargate is offline
Old 02-16-2006, 08:49 AM   #5
bearartst is on a distinguished road
question
Can you tell me where you purchased this console? I would really like to buy one.
Thanks.
bearartst is offline
Old 02-25-2006, 11:26 AM   #6
jmseals is on a distinguished road
Send a message via Yahoo to jmseals
looks great!! same question, where can i get one? price?? thanks
jmseals is offline
Old 03-08-2006, 01:18 PM   #7
slow4drinteg is on a distinguished road
what did you use to cut the liner? very clean cuts.
slow4drinteg is offline
Old 10-23-2006, 06:14 PM   #8
Brian is on a distinguished road
He used a razor blade in a utility knife. Always use a new blades and punch through the headliner slowly, NEVER PULL- you can and will slip.
Brian is offline
Old 11-18-2006, 07:02 AM   #9
redbox is on a distinguished road
Materials
1 maplight housing
1 metal epoxy
masking tape
Tools:
Wiring
Hope this helps.
Attachment 688
Attachment 689
Attachment 690
Attachment 691
Attachment 692
Attachment 693
How much depth is between the headliner and roof ? What type of metal epoxy did you use? What type and how did you attach the foam spacers? How far did you have to pull the headliner down to make it meet the housing?
redbox is offline
Old 05-03-2007, 02:43 AM   #10
focus_guy is on a distinguished road
Re: Custom Roof Console
good question, would you recomend recovering the headliner?
focus_guy is offline
Old 05-07-2007, 12:33 AM   #11
ricknute's Avatar
ricknute is on a distinguished road
Nice mod, I think I shall add one myself. I hope to figure out how to put one of the trip comps up there like mopar has.
ricknute is offline
Old 06-07-2007, 04:12 AM   #12
TheProfessor is on a distinguished road
I know this thread is like a year old, but does anyone know where you can get a maplight like this??? That would be awesome
TheProfessor is offline
Old 06-07-2007, 10:22 AM   #13
Hit up your local junkyards. Look for a wreck that has one close to the size you need. That's what I did.
Old 06-07-2007, 11:49 AM   #14
i love my box
Yaksha808's Avatar
Yaksha808 is on a distinguished road
taz, just wanted to congratulate you again!
Yaksha808 is offline
new console royle_bboxer General Scion xB Discussion 1 01-03-2006 12:14 PM
CA: custom billit grill bluebb05 Scion xB Classifieds 0 12-16-2005 09:35 AM
DIY: Covering the door panels
DIY headrest monitor install
Removing the Center Dash Trim
Custom Roof Console
DIY: Homemade Boo Boo's.
Ignition switch cover
Page generated in 0.21997 seconds with 15 queries
